FOS Harbor Master Office build.
Started by ACL1504, July 21, 2020, 06:12:20 PM
Quote from: Janbouli on July 23, 2020, 07:48:16 AM
Following along Tom
Jan,
Happy to have you back and following along on this adventure.
Quote from: S&S RR on July 23, 2020, 11:08:21 AM
I will be following along - I'M interested to see what you come up with.
Thanks for following along on this one.
Don't forget this is my BUILD THREAD and not a food thread! ??? ??? Just saying.
Tom 8)
This morning I removed the walls from the carrier sheets. Be careful with the small door as it is fragile. No, I didn't break it but I've learned from past experience which pieces are prone to breaking. The small door is one such piece.
When the laser cuts a section or wall, it leaves a burnt/brown edge. This edge is referred to as a "kerf". The laser also cuts at a slight angle so I make it a habit of sanding the "kerf" back to square on the edges. I use a large sanding stick and firmly hold the wall section and lightly sand the edge until the "kerf" or edge no longer shows a burnt edge.
I try to follow the 6 P principle. Proper Planning Prevents a P--s Poor Product.
In the photo below, you can see the sanded wall edge on the left.
Sanded edge is on the top.
I do this so the corner trim fits flush against the wall edge and not show a slight gap if not sanded.
Continued -
I also add extra bracing to the walls. Florida is a humid state so the extra bracing helps. I especially like adding extra trim to the gable ends of wall sections.
I start on one side, glue the brace and when dry, cut is as shown below.
The angle of the cut piece is the same angle as the top of the gable as shown below. Glue this in place and cut off at wall edge.
Continued -
You can see the cut piece is the same angle. Glue this in place and then glue the left over piece vertically.
Back in a few. Diet Pepsi time.
In the photo below, you can see the extra bracing on the gable ends. I've marked in red ink the extra bracing.
The extra bracing is also an added support for the roof panels when they are added.
When all the bracing is dry, I go back and lightly sand the edges again to remove any glue that may have squeezed out as the bracing was drying.
Next is staining and painting.
Quote from: ACL1504 on July 23, 2020, 04:24:12 PM
Tom 8)
Got the message.....won't chat about chicken fried steak then.  ::)
Looking forward to seeing your progress Tom.
Quote from: GPdemayo on July 23, 2020, 05:18:22 PM
Tom 8)
Oh brother, apparently not!
Quote from: PRR Modeler on July 23, 2020, 05:21:01 PM
Thank you for following along.
Bruce Oberleitner
Hi Tom,
Looks like another cool project for your railroad is afoot!  can't wait to see what it looks like when it's finished.
BTW, with Doug's kit of the month program, does he include instruction with them?
Nice job Tom.  I like that extra bracing to keep it right.
Not a bad idea for kits like that in Jersey with the humidity here this year!
Coming along nicely Tom!  Extra bracing is always a wise thing to add.
