Great Lakes Lighthouse Build
Started by carl b, January 01, 2020, 11:43:41 AM
carl b
Carl
Carl
This project is coming along nicely. The craft store is a world of parts for the scratch builder.
carl b
Thank you John.
I never pass up a trip to those stores, never know what you may find.
Carl
Nice work so far Carl.
Thanks for the tutorial on how this all comes together.
carl b
Thank you very much Jerry.
More to come in a few days...
Carl
Hey Carl:
Thought that lighthouse looked familiar. Check out Branchline Trains kit #695 HO Rock Point Lighthouse Kit. I think you will be surprised.
Here's A lighthouse sight all might be interested in. www.uslighthouses.com I find it to be very fun to look at and is rather complete listing.
carl b
Right Karl, I mentioned this kit in my first post. It's very close- but they used clapboard instead of brick for the walls.
Karl, didn't you post a build for this back in 2007 on RRLine?
Carl
Hey Carl:
thanks for the picture.
carl b
A decagon is a 10 sided polygon. I drew it with an on-line graphics generator, available here: https://www.mathopenref.com/decagon.html The Dunkirk Lighthouse tower has 10 panes of glass around its lantern.
I printed out several sizes and glued them to thin and thick card, in anticipation of much trial and error.
Cut out a proper size thick card version decagon, which is the base for the "French" dome. Then I cut the wood ball in half. Then styrene strips for the roof "ribs". Topped off with the previously finished evaporator ball and needle..
The lantern housing begins with a thick card but smaller decagon. I used masking tape to measure around the circumference to determine the overall length of acetate for the needed windows. I measured, then LIGHTLY scored the 10 panes, and bent them ever-so-gently in shape.
Again from the craft store, a bag of cheap clear multi-faceted beads. No, I couldn't buy just one.
They don't look exactly like a proper third order Fresnel lens, but that would have been made of real crystal, and cost a fortune. Not likely....
There's already a hole in the center of these beads, so I simply slid an LED inside and glued it.
Glued the bead to a base of a short piece of styrene tube. Test fire of the light.
The hand railing around the lantern glass is .016" brass. To roughen up and clean the brass before soldering, I used 150 grit sandpaper and Isopropyl alcohol. I pre drilled the upright holes in the base according to the out points of the decagon. Inserted the deliberately long posts. It's sitting on a "holder" of 1 1/4" bathroom plastic pipe.
I glued the posts standing up in their places. I bent a long brass section around a small bottle cap, until I got the right size for the railing when it "sprung back". Then soldered all in place. It's very messy right now. Needs filing, straightening and tweaking..
I placed thin white window muntins between the panes before folding and gluing down. Much sanding, fitting, fidgeting and cursing, but finally, all the pieces painted and glued together.
Till next time...Finish the carcass.....
Carl
WOW, great scratch building and use of unconventional materials.
I see your up to your old tricks of using everything under the sun to make a perfect scratchbuild.
Just love your work.
Very nice, Carl!  And you've got 149 clear beads left!
carl b
Thank you very much for your compliments Curt, Jerry, Greg, Bob and Mark!
I appreciate your support.
Mark- Would you like some of those extra beads?  ;)
Carl
