Kjeungskjaer lighthouse
Started by madharry, October 07, 2019, 10:06:55 AM
It's looking good.  I'm enjoying following along.
a bit late to the party Mike, but I'll be looking in.....neat lighthouse.  :)
madharry
Thanks Curt, John and Gregory, it is much appreciated.............
Working on the light area. I found an acrylic bottle cap the right scale size. I removed the black roof and cut a new one around the cap and then added the new black roof as a surround. To the cap I added some red masking tape as in the pictures there appears to be red baffles inside the light housing. I then measured the roof and angle of the light housing roof. I cut eight card formers and glued them on top...............
WOW, beautiful job on a very small and many pieces part.
madharry
madharry
Moving on...............I tried to cover the roof on the light with eight pieces of angled card. Using an Olfa cutter I scribed several card circles which I then cut into eigths. After the sixth attempt I gave up trying. Instead I used some DAS clay to form the roof cap filling in between the card formers. The metal addition was found in an box full of FSM castings.
madharry
I added wood coffee stirrers to the inside walls of the plasticard body of the lighthouse. This aids the glueing in of the windows..............
madharry
Prototype and model..................
madharry
Continuing...............I added the led light to the structure. In order for it to remain within the building and not slip out of alignment I hot glued the wires to the base of the lighthouse. The led light flashs every six seconds.
madharry
Around the base I added some thick double sided tape to represent the stone walls. I deliberately weathered this by removing the paper from the tape and touching it at various places before spraying with paint.
madharry
Thanks Jerry, it is much appreciated.
I added some half round strip styrene to the top of the walls just under the roofline.
Great job Mike. Can you do a short video with the flashing light?
Superb Mike , that will look great on the layout.
madharry
Thanks Curt omce it is on the layout I will try and get Mrs C to do a video, She is smarter than me.........
