CCK Cape Fear Bunkhouse AKA Rockingham Co. Grange Hall No. 6
Started by Raymo, February 17, 2014, 07:57:29 PM
Raymo
I spent the rest of my morning cutting the rafter tails to be added after the roof sets up
Raymo
Raymo
Trying to get back on track with this build, I was able to get the rafter tails glued to the underside of the roof and fascia boards to the ends
Raymo
I spent alot of time figuring out and building the enclosed staircase for the end of the building.I didn't spend any time taking pictures documenting it but here's the end result after applying the A&I wash.
Raymo
Checking the fit to the building
Raymo
I painted it to match the building and attached it to the building. I then cut the roof pieces to fit and added them to the stairway.
Raymo
I cut the roofing down to a scale 4'x8' pieces and painted them with grey automotive primer and then dry-brushed them bright silver
Raymo
I applied some pre-colored tar paper I had on hand to the enclosed stairway
Raymo
I then used some 4x4 stripwood to build the stairway support. I'll add another support part way down the stairs but not till the end of the build
Raymo
Some transfer tape was applied to the roof and the roof panels were applied
Raymo
Thats it for this installment,I'll try to post more progress tomorrow. Raymo
The outside stairway is really cool with the upper brackets.
see ya
DEFugere
Enjoying your build, color choice is spot on. I've grown to love covered outside stairs. I am adding one to my scratch build. Good progress!
David
Raymo
Bob,Tom,and Dave,Thanks for your comments on my build. I never would have thought that back stairway would have taken as long as it did to build,but I'm happy with the results. I had a W.T.F. moment this weekend when I put a small tip on my super glue bottle to flow some along the peak of the roof. All went well for the first inch until the tip fell off and I dumped a big glob on the roof. Luckily I keep a can of compressed air near the workbench and I blew as much as I could off the roof  before it set up. After it dried,I sanded the affected panels with some fine grit sand paper down to the paint without wearing through. When I gave the roof an A&I wash, they weathered up like the rest of the roof so I got a pass on that mistake.
