FSM Fox Run Milling - scratch/kit bash
Started by ACL1504, September 02, 2019, 05:50:34 PM
I then glued the building together in halves.
I also glued sub assemblies together as shown below.
The main building was glued together. Clamps were used to make sure it was square and stayed square as the glue dries.
When the glue dries, the moisture evaporates and the glue has a tendency to pulled walls out of square, even just al little. This is why I always use clamps to hold the walls square until the glue is completely dry.
I also use squares to ensure the four corners are set prior finalizing the clamps.
Looking good Tom!  Another great tip on kit construction.  In a previous post I saw that you cut a piece of timber to use for glue removal.  I use a #17 chisel blade to do the same thing.  Really helps to get that overflow of glue out of the way.
Remember that day in high school geometry class when you thought - "when would I ever need to use this stuff."  Well, that day is here.
Quote from: Oldguy on September 12, 2019, 10:37:01 PM
My brother was a pro carpenter.  He used to amaze his co-workers by using trig to figure out the length and angles for boards, etc.  (The common approach was 'trial and error'.)
Quote from: deemery on September 13, 2019, 10:28:23 AM
Aha, that explains it. The trial & error crew must have been the ones who built my house long ago. Not a square joint in the place.
--George
As usual, coming along nicely with your ever present clear explanations throughout the build.
Quote from: MAP on September 12, 2019, 06:23:23 PM
Mark,
Thanks very much. I have used #17 blades in the past but I kept getting them caught on the bracing.
Yes, I remember making that comment several times on most of the high school classes. I only took math classes in JUCO but none at UF.
;D
As a young boy, I would watch the carpenters who worked of my father's construction company. Some of the cuts amazed me. I remember when one of them told me about the Fibonacci spiral. Amazing.
Quote from: Opa George on September 13, 2019, 11:10:56 AM
--George
George,
I think the "trail and error" method is still used for most, if not all, new house construction  today.
Quote from: S&S RR on September 14, 2019, 09:51:02 PM
Very fine work my friend.
Thank you very much my friend, much appreciate you stopping by.
Quote from: jerryrbeach on September 16, 2019, 08:45:29 AM
Jerry,
Thank you for the kind compliment. I took a Creative Writing class while at UF, the prof. said, "If at all possible, write as clear and unambiguous as possible." Then he said, "Then on the other hand, it's mostly not possible."  We all had that deer in the headlights look.
The four main walls are now glued together. I plan on having some interior lighting so I added a floor to keep the first and second floors from looking like one big light. I'll add some interior walls out of cardboard later.
Continued -
