Advertise Here - SUPPORT TMF
Author Topic: 2x4 or 1x4  (Read 1589 times)
DennisBourey
  • Modeler's Hero 500+ Posts
    • View Profile
2x4 or 1x4
« on: December 01, 2019, 04:28:02 PM »
Well,  I went to lowes today for some stuff and I looked at the lumber. 2x4x8 are $2.62 and 1x4x8 are $6.82 each what do you guys use for your layout? That's quite the difference if you building a good size layout? Thinking of 12x20 and was wondering what to use? Or rip 3/4 plywood? Dennis
sdrees
    • View Profile
Re: 2x4 or 1x4
« Reply #1 on: December 01, 2019, 04:57:05 PM »
Hi Dennis,
I used 1x4's L-girder construction for the joists and 2x2's for the legs.  When you get your lumber from Home Depot or Lowes make sure you get pieces that are straight, because a lot of them are warped.
Here is the link to my layout construction where I go into detail on the construction of the bench work for my layout.
http://www.modelersforum.com/index.php?topic=1811.0
Steve Drees
SP RR
  • T-Shirt - FORUM SPONSOR
    • View Profile
Re: 2x4 or 1x4
« Reply #2 on: December 01, 2019, 05:08:35 PM »
Dennis
I used 2x4 for exactly the same reason about 1/3 the cost (I bought the #1 Pine 2x4's for the new section for 1.89 at Menards).   The 1x4 L girder makes nice clean looking benchwork but I never could justify the cost. My 2x4 benchwork is supporting 3400 lbs of plaster and has no issues holding me when I climb around on it. I started with a 3/4 inch plywood top. I cut holes when I want the landforms lower and add pink styrofoam to go up now.  In the past the larger mountains were made with a cardboard mesh and plaster.
« Last Edit: December 01, 2019, 05:13:58 PM by S&S RR »
rpdylan
    • View Profile
Re: 2x4 or 1x4
« Reply #3 on: December 01, 2019, 06:11:17 PM »
I make my own 1x4 using 3/4 plywood,,,,, very cost effective, stable, and straight!
Bob C.
    • View Profile
Re: 2x4 or 1x4
« Reply #4 on: December 01, 2019, 06:55:19 PM »
Dennis,
My local Lowe's has the absolute worst 2x4's I have ever seen.  On my last visit I must have picked through thirty or more of their more expensive ones to get two that are straight with no warping or twisting so I could use them for 2x2 legs.  I find their 1x4's are less expensive per foot and better quality if you buy the sixteen footers.  I cut them to shorter lengths in the parking lot with my battery powered circular saw to make it easier to get them home.  Bob is on the money, if you can accurately rip 3/4 plywood sheets into 1x4's it does cost less.  I am building my layout as individual modules so weight is a factor for me.
« Last Edit: December 01, 2019, 07:09:39 PM by jerryrbeach »
    • View Profile
Re: 2x4 or 1x4
« Reply #5 on: December 01, 2019, 07:01:40 PM »
I'm with Steve, 1x4 L Girder on 2x2 posts.
    • View Profile
Re: 2x4 or 1x4
« Reply #6 on: December 01, 2019, 08:01:07 PM »
Like Bob C., I rip 3/4 in plywood into 1x4s and 1x2s for L girders.  I invert the L girders.  Cut 2x2s to use to attach the 1x4s as cross members.  I do this as it's easier for me as a lone wolf modeler to build the benchwork myself.  I use 2x4s (searching through a large pile at Lowe's for a straight one) for the legs.
DennisBourey
    • View Profile
Re: 2x4 or 1x4
« Reply #7 on: December 02, 2019, 12:43:37 PM »
Steve I'm about half way through you build WOW!!! Dennis
DennisBourey
    • View Profile
Re: 2x4 or 1x4
« Reply #8 on: December 02, 2019, 12:45:16 PM »
Thank you, You guys are  asset to this hobby. Dennis
    • View Profile
Re: 2x4 or 1x4
« Reply #9 on: December 02, 2019, 01:14:07 PM »
For you guys who do ripped-down plywood:  How do you do this?  Seems to me A LOT of work to rip plywood that way.  Is there some particular tool or set-up you do to make this feasible?
mark dalrymple
    • View Profile
Re: 2x4 or 1x4
« Reply #10 on: December 02, 2019, 01:48:26 PM »
If Lowe's timber is so crap why doesn't everyone shop at a timber merchant?
    • View Profile
Re: 2x4 or 1x4
« Reply #11 on: December 02, 2019, 02:20:14 PM »
Those are pretty scarce in the US these days!
    • View Profile
Re: 2x4 or 1x4
« Reply #12 on: December 02, 2019, 02:30:41 PM »
They sure are - I have found that the quality of the lumber at Mernards is much better than HomeDepot and Lowes. We have all three within a mile of one another.  I still go to our local lumber yard when I have big projects.
DennisBourey
    • View Profile
Re: 2x4 or 1x4
« Reply #13 on: December 02, 2019, 04:22:22 PM »
Hi guy's, I found HD has better lumber then Lowes. And other lumber yards just don't exist around the two big box stores. At least in my area I found one but it's way to far to make a run.  Dennis
DennisBourey
    • View Profile
Re: 2x4 or 1x4
« Reply #14 on: December 02, 2019, 04:25:20 PM »
Mark, I'm not sure if there's a timber merchant in the state's  ? Dennis
