Advertise Here - SUPPORT TMF
Author Topic: 2x4 or 1x4  (Read 3037 times)
NEMMRRC
  • Modeler's Hero 500+ Posts
    • View Profile
    • Narrow Perspective
Re: 2x4 or 1x4
« Reply #15 on: December 02, 2019, 07:03:58 PM »
84 Lumber is basically a "timber merchant" in the USA. It is not found everywhere though.
Often there is a local lumber (what we call it in the USA) supplier in most cities. It may not be well known as they don't advertise heavily and may not have "retail friendly" prices and quantities.
Jaime
Dennis Bourey
    • View Profile
Re: 2x4 or 1x4
« Reply #16 on: December 02, 2019, 09:27:16 PM »
Jaime, I found some but the closet is in Mass and New York :( Dennis
Lake's Region RR
Rail and Tie
  • Senior Poster 250+
  • ...look, cows!
    • View Profile
    • Interaction Hobbies
Re: 2x4 or 1x4
« Reply #17 on: December 02, 2019, 09:52:48 PM »
For you guys who do ripped-down plywood:  How do you do this?  Seems to me A LOT of work to rip plywood that way.  Is there some particular tool or set-up you do to make this feasible?
Dave, if you have a table saw it is pretty easy. I also use my tracksaw which is a glorified skillsaw with a guide. If you are doing lots of 3/4" x 4" strips, a track saw or skill saw conversion is a good investment. I use my track saw for breaking down sheet goods and it certainly saves the back and divorce issues when I get my wife to help me on out feeding the tablesaw!!
Darryl Jacobs
Inter-Action Enterprises
www.interactionhobbies.com
mark dalrymple
    • View Profile
Re: 2x4 or 1x4
« Reply #18 on: December 03, 2019, 03:13:06 AM »
Wow!  There are oodles of them In NZ!
Cheers, mark.
    • View Profile
Re: 2x4 or 1x4
« Reply #19 on: December 03, 2019, 07:38:37 AM »
To answer Dave's question about the plywood sheets.  I have the Lowe's (or the local lumber company) rip them in half lengthwise first.  I'm to old to lift a 4' x 8' sheet myself.  This size is relatively easy to feed into the table saw.  Lowe's plywood (I use the birch veneer) is much better quality than their stick lumber.  Their saw is often out of commission, however.   I then go the the local company.  The quality is a bit better but the price is much higher.  I think $10 a sheet the last time I was there a couple of years ago.
rpdylan
    • View Profile
Re: 2x4 or 1x4
« Reply #20 on: December 03, 2019, 08:26:58 AM »
I agree with the birch plywood, very cost effective in making 1 x 4s. I use a Kreg rip guide on my circular saw with a fine tooth blade. Its easier for me to rip the sheet this way.
Bob C.
    • View Profile
Re: 2x4 or 1x4
« Reply #21 on: December 03, 2019, 08:55:25 AM »
Goose Bay Lumber!  https://goosebaylumber.net  They're just east of Concord.  Don't know how their prices are, though.
  • T-Shirt - FORUM SPONSOR
    • View Profile
Re: 2x4 or 1x4
« Reply #22 on: December 03, 2019, 11:28:06 AM »
I have been following along on this discussion and thought I would add my 2 cents, again.  If you are going to use the plywood strip method (nothing at all wrong with it) but make sure you use exterior grade plywood.  We tend to get things wet when we add the scenery and interior grade (water soluble glue is used to bond the plywood) can be very problematic.
    • View Profile
Re: 2x4 or 1x4
« Reply #23 on: December 03, 2019, 11:33:24 AM »
Cheers, mark.
When I was working on my addition to the layout this summer I noticed that the trim wood and moldings that I bought had "made in New Zealand" stickers on them. It amazes me that you can ship a piece of wood all the way from New Zealand and still be cost competitive.
Dennis Bourey
    • View Profile
Re: 2x4 or 1x4
« Reply #24 on: December 03, 2019, 12:26:11 PM »
WOW!!!! Thanks guys. Dave I will check them out thanks...Dennis
Lake's Region RR
  • Modeling the B&M's Eastern Route in HO 1950 - 1965
    • View Profile
    • New England RR History & Modeling Info
Re: 2x4 or 1x4
« Reply #25 on: December 04, 2019, 06:27:54 AM »
A 2x4 is more wood than you need for most model RR benchwork.  Installing building foundations, wiring, switch machines and landforms often require working under the layout, and I've found extra wood is more likely to get in my way.  If most of a section of layout will be on a plywood tabletop, the size of the framework may not matter as much.
    • View Profile
Re: 2x4 or 1x4
« Reply #26 on: December 04, 2019, 06:46:38 AM »
I used 2 1x4's for the main L-girders and 2x2's for the legs (2 of which extend up to support the central backdrop), but otherwise I'm only 1x2's throughout. I am careful to buy the better grades of wood and to examine for warpage before I purchase. My layout is also in a climate controlled environment in a warm climate, so I may not be subject to some of the expansion problems some others face. I'm a big fan of homasote and, generally, don't even support it with plywood. I just space risers out every foot or so...my scenery is lightweight foam and/or cast foam rocks. The only plywood I use is very slim and used for riverbeds, etc. and is well supported by 1x2 crossbeams beneath...I understand these are "flimsy" choices but so far, so good.
    • View Profile
Re: 2x4 or 1x4
« Reply #27 on: December 07, 2019, 10:18:08 AM »
Thanks for the tip regarding getting the sheets ripped in half.  I just picked up a sheet of 3/4" plywood from Lowe's and having it ripped lengthwise made it very easy to manage.  I feel like kicking myself for never having thought of this myself.
