Advertise Here - SUPPORT TMF
Author Topic: FSM Chippy Hollow Hardware  (Read 4087 times)
  • Modeler's Hero 500+ Posts
    • View Profile
Re: FSM Chippy Hollow Hardware
« Reply #60 on: February 20, 2020, 10:01:19 AM »
Something to try on the corrugated roof:  rub a soft pencil on it, which will add a small amount of 'graphite shine'.  If you don't like the effect, it'll be easy to clean off with water or alcohol.
hairball
  • One Hundred Post Club
    • View Profile
« Reply #61 on: February 20, 2020, 10:10:34 AM »
all the stacks and vents on the roof.   You need tar flashing.  White glue applied with toothpick and then very small pointed brush to apply black paint to simulate tar.  All adds greatly to the finished look.
mike lynch..............HAIRBALL
  • Modeling the Pennsy
    • View Profile
« Reply #62 on: February 20, 2020, 11:23:04 AM »
Beautiful modeling.
    • View Profile
« Reply #63 on: February 20, 2020, 11:53:50 AM »
Great detailing Steve.
    • View Profile
« Reply #64 on: February 20, 2020, 05:03:25 PM »
Good choice keeping the cast metal shed roof. It's gorgeous with detail. Also a good job in getting the cast metal wood stairs to match the weathered wooden decking. That can be tough to get close, but you did it.
--Opa George
George Nagle
Harrisburg, PA
Tiger Mountain Barge & Navigation Company
SteveCuster
  • Senior Poster 250+
    • View Profile
    • ScaleModelWorkshop.com
« Reply #65 on: February 28, 2020, 09:55:59 AM »
Thanks everyone.
I added the roof to the brick structure.
This is the way I install my chimneys. I drill a hole in the center and super glue a toothpick in place.
All the chimneys are secured with Liquid Leading. This secures them and looks like roofing tar.
Mike, I use Liquid Leading to represent roof tar. Its a flat grimy black colored glue from any craft store. I think it's used for stain glass windows. I try to have it hardly visible around the chimneys if possible. All the main roof chimneys were installed this way.
I started adding the shingles. Same as before.
I glued the building to the main structure before I finished the final row so I could get the shingles right up to the stone.
    • View Profile
« Reply #66 on: February 28, 2020, 10:20:26 AM »
Beautiful shake shingle roof on the brick. I like the contrast of the brick and shakes with the stone main structure. Very striking!
--Opa George
George Nagle
Harrisburg, PA
    • View Profile
« Reply #67 on: February 28, 2020, 10:23:44 AM »
That is coming along nicely.
    • View Profile
« Reply #68 on: February 28, 2020, 02:48:05 PM »
Looks really nice.
    • View Profile
« Reply #69 on: March 03, 2020, 05:29:37 PM »
Steve when you get a chance.  I sent you and email here under messages.
SteveCuster
    • View Profile
« Reply #70 on: March 04, 2020, 09:56:22 PM »
Thanks everyone!
I finished adding the shingles and colored them using the same methods as the main roof.
I added a couple pieces of corrugated metal to the roof to represent a makeshift repair and add a little character to the roof.
Now that the roof is in place I started adding the downspouts. They are made with thick wire bent with a set of needlenose pliers.
I also added the downspouts to the other side of the structure.
I added some wire supports and weathered with some rust powders. I'll add moss and vines once I get the ground cover down.
Thanks for following along.
Next step is laying the tracks and the base ground cover.
    • View Profile
« Reply #71 on: March 05, 2020, 05:58:52 AM »
Great work Steve!
    • View Profile
« Reply #72 on: March 05, 2020, 08:14:14 AM »
Very nice build Steve.
    • View Profile
« Reply #73 on: March 05, 2020, 09:24:06 AM »
Wow...that is some fantastic work. The roofing, stonework, and overall weathering is really great!
    • View Profile
« Reply #74 on: March 05, 2020, 10:51:11 AM »
Agreed--all beautiful work. I particularly like your downspouts.
--Opa George
George Nagle
Harrisburg, PA
