Advertise Here - SUPPORT TMF
Author Topic: Bar Mills Seckler's Cold Storage Background Flat for the A&S  (Read 3644 times)
  • T-Shirt - FORUM SPONSOR
  • Modeler's Hero 500+ Posts
    • View Profile
Re: Bar Mills Seckler's Cold Storage Background Flat for the A&S
« Reply #30 on: February 10, 2020, 07:26:16 AM »
After I add the bracing to the walls I weigh them down for a few minutes until the glue grabs.  I have few marble blocks scavenged from old bowling trophies I use for this.
The bracing was squared up with one end of the wall and overhangs the other end.  I trim it to fit by flipping the wall over and cutting it with a single edge razor blade.
Once the walls have been braced I started finishing them.  First a coat of the Hunterline Light Gray Weathering Mix (being careful not to get any on the stucco finish lower wall section.
Next up I painted the clapboard walls with PollyScale Reefer White.  Normally I'd thin it a bit my dipping my brush in water then the paint but the last few bottle of PollyScale I bought were pretty darn thin to start with so I didn't bother doing that.
I then 'dry sponged' some Folk Art Dove Gray onto the walls.  It's really hard to see this light gray color on the white walls but it does make a difference.  It's supposed to represent places where the white paint peeled away and the primer beneath is showing.  I first dab the sponge in some paint and then on a piece of scrap paper to remove most of the paint.  I'm not trying to paint the walls with the sponge.  I'm just trying to speckle a little bit of paint onto the walls.
Then I repeated the 'dry sponging' with some Folk Art Khaki Tan to represent places where the wood was showing through the paint.
More in a moment... ;)
    • View Profile
« Reply #31 on: February 10, 2020, 07:37:46 AM »
Next up I added some nail holes using a steel straight edge and a ponce wheel.
After the nail holes were added I beat up the walls a bit by lifting individual clapboards here and there by slipping a chisel blade beneath them and, in some cases, twisting it slightly to break a small piece loose or off entirely.
I cut out the big sign for the front wall a little bit oversized in preparation for distressing it.  A nice touch, the kit comes with two signs in case you mess one up.   ;)
I start by sanding the back of the sign to make the paper as thin as I can get it.  Be careful not to sand through it or tear it!
I used fine steel wool on the front of the sign, scrubbing from the top down, to take the edge of the black ink and lighten it up just a wee bit.
Jumping around (I'm doing a lot of that on this build) I next prepped the roofing material.  I first sprayed it with a rattle can paint (don't have the can handy right now that) that's a chalkboard black.  Then I used pan pastels to turn it gray.  More on this later when I apply the roofing material.
After installing the windows I tried using the precut glazing but found it didn't quite fit to my satisfaction and required a little trimming so I immediately aborted and used MicroScale Industries Kristal Klear for the glazing instead.  There are other glues (e.g. Canopy Glue) that can be used for this but I like working with the KK.  Working from the back just draw it across the opening to form a film.
    • View Profile
« Reply #32 on: February 10, 2020, 07:49:11 AM »
I painted the back of the clapboard walls black with a cheap craft store acrylic.  I should have done that after I installed the bracing and before I did anything else but I forget.  Not a problem.  Just had to be a little more careful because the windows were already in place.  Next I added window shades made up of a sheet of printer paper painted light green on both sides and trimmed to fit over the window openings.
A little glue around the window opening first.
Then put the shade in place.  Vary the height from window to window a little bit.  No need for them all to be drawn exactly the same amount.
Back to the roofing material.  I cut the sheets into 9 scale foot lengths.  I'm experimenting a bit with the roof because I know where Tom plans on putting this structure (on the summit) the roofing material isn't going to be visible except to visitors who are 7+ feet tall.  :o  I applied 3M Transfer tape to the cardstock roof first even though the material include in the kit is peel and stick.  I've never found the 'stick' of the material included in some kits to be good in the long run.  I applied the strips in a pattern by offsetting the end seam each row by 1/2 of that of the adjoining row.
Pitch was then added to all the seams.  This is simply white glue mixed with PollyScale Grimy Black paint.
When I glued the walls together I had some joints where the stucco walls met.  I went back and stippled on more paint/Durham's Rock Hard Water Putty to cover up the joint.  I protected the brick patches and other things with Blue Painters tape while I was doing this.
More in a moment.... ;)
    • View Profile
« Reply #33 on: February 10, 2020, 07:56:23 AM »
After gluing the large sign to the front wall with a thinned out white glue I dry sponge some of the same cream color I used on the stucco walls over the large sign to age it a bit more.
Next I added the trim along the top of the walls.  This took a fair amount of time.  There are a couple of pieces of strip wood at the top of each wall and I mitered the corners for a clean fit.
More trim being added.
For the stucco walls one needs to cut a bunch of the these 3/32" inch square by 1/8" long pieces.  I used my NWSL chopper for this.
I used the strip wood I was cutting to clear the piece I just cut from underneath the blade.  I learned the hard way not to use my finger for this.   :P
These little pieces get glued into notches cut into the top of the stucco walls.  After they were glued in place I stained the ends and then touched them up with Reefer White followed by A&I to finish them.
That's all for today!  Thanks for following along.   :)
    • View Profile
« Reply #34 on: February 10, 2020, 08:22:09 AM »
Another great build and build thread Bob.
  • Modeling the Pennsy
    • View Profile
« Reply #35 on: February 10, 2020, 08:53:30 AM »
Looks like a great build Bob.
rpdylan
    • View Profile
« Reply #36 on: February 10, 2020, 09:41:06 AM »
Picked up this kit at Springfield,,,, thank you for the build thread,,, looks great!
Bob C.
    • View Profile
« Reply #37 on: February 10, 2020, 11:21:15 AM »
Looking very good and great tutorial as well.
mark dalrymple
    • View Profile
« Reply #38 on: February 11, 2020, 01:33:03 AM »
Looking fantastic, Bob!
    • View Profile
« Reply #39 on: February 11, 2020, 08:18:43 AM »
Thanks John!  This one's been a little challenging but a lot of fun too.  :D
    • View Profile
« Reply #40 on: February 11, 2020, 08:20:02 AM »
Thanks butty!  Making progress on this one.  A lot of vents and other assorted goodies to add yet.  Those should really spice it up.  ;D
    • View Profile
« Reply #41 on: February 11, 2020, 08:20:40 AM »
I'm looking forward to seeing your build when you get around to it.  It's a neat structure for sure.   ;)
    • View Profile
« Reply #42 on: February 11, 2020, 08:21:26 AM »
Thanks Tom!  I think it'll look good on the Summit.   ;D
    • View Profile
« Reply #43 on: February 11, 2020, 11:46:02 AM »
Looks great Bob. Love the way you explain everything.
Oh so that's what happens to old bowling trophies!!  :)
    • View Profile
« Reply #44 on: February 11, 2020, 08:41:53 PM »
Thanks Jerry!  Now if I could only figure out what to do with old bowling balls.  I haven't thrown one in two years and it doesn't look like I'll be doing it again anytime soon.   :D  I used to be decent at it but not anymore.   ;D
