scratch building a wood trestle
Started by rustyfawcett, December 21, 2013, 12:53:58 PM
rustyfawcett
well keep up to date on the build. I plan on getting a few more bents done today.
rustyfawcett
so I got a hold of tichy and they sent me some samples of nuts bolts and washers and ended up using tichy #8034 1.75 bolt,3" square nut and 6 inch washer. just need to drill 300+ holes and glue them in. I know that I made a slight mistake by not priming and painting these ones but I have a steady hand  ;D ;D ;D
Looks good to me.  Looking forward to this build.
Rusty........
Great build.  Regarding the NBW castings.  Find a drill that is very close to what the pin on the casting is made to.   Then snip the castings off of the spru with a dull, not Xuron..  and that flattened out end will help hold them in.  Then blast the finished bent with dull cote. That will be enough binder to hold the casting into the wood.
see ya
rustyfawcett
Quote from: bparrish on December 23, 2013, 08:07:03 PM
Rusty........
see ya
thanks bob. that is why I like the site. I would not have thought that. thanks for the tip
ak-milw
Hey Rusty, I have found that if you hit the bolts with a dull coat finish after your done the color of the bolt isn't far off from a rusty one. I normally just add streak marks.
8)
rustyfawcett
Quote from: ak-milw on December 24, 2013, 02:26:16 PM
8)
thanks I will have to try that
rustyfawcett
Castings came in today. Time to get to work....
Very nice job Rusty...love the look of the wood!  ;D
rustyfawcett
update not much done but still moving along. I changed my mind on what I wanted. I wad going to use this for going on a small rocky gorge. but sine then I have decided to make it going over a road. this is where I am at for now. two more of the small bents for over the road then finish the castings. I hope to start putting it all together in the next week or so,.
ak-milw
Bntrainmaster
Looking great. Keep up the good work and thank you for sharing.
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
barrymk
You'll go insane drilling those holes!  You may want to keep it here but If you want to get rid of the fuzz on the wood, a quick (and I mean quick :o) pass over a small flame will remove them.  And yes I do have a fire extinguisher on my workbench!
PHQRR
Looking good!!   I'll put in an order for a couple dozen...any size I'll make'm fit...Heheheheh ;D ;D ;D
