FSM Branchline Bucket Coaling Station
Started by SteveCuster, February 10, 2021, 06:24:14 AM
Hey Steve:
Looking just beautiful so far.
Steve, love the look of that. Those interior shots are fantastic.
--Opa George
SteveCuster
Thanks everyone for all the positive comments and for taking the time to comment.
Todays update: I got the front wall installed, added the ridge support and started the rafters.
Front wall is built and installed. Both the front and rear walls needed to be notched for the ridge board. I had already notched the rear before I glued the walls together but the front was a little more challenging. The small assembled front wall section is very fragile.
The rafters are being installed. They need to be notched to clear the tops of the side walls. I stopped here but I should be able to get the rest of the rafters installed today, hopefully most of the roof boards as well. Everything is already colored and weathered so it's just a matter of installation.
Thanks for following along.
Steve Custer
I suspect 1-1 scale carpenters find notching rafters is annoying, too :-)  (I'd ask my brother if he was still with us.)
Wow!  Birds mouths.  How flash.
Looking good.
craftsmankits
Looks awesome.  Enjoying this build.
Extremely well executed. Most of the other superlatives were already used.
Beautiful work as always, Steve!!
I've got one of these kits that I will never build...If anyone is inspired, PM me
SteveCuster
Thanks everyone!
I made some more progress on the roof between yesterday and today.
All the rafters are glued in place.
All the roof boards are in place. I beat some of them up but not as aggressive as the walls.
I wanted a really beat up tarpaper roof to match the beat up structure. I used black tissue paper sprayed with black primer.
The other side..
Next step is building the rear shed.
Steve Custer
PaulS
Just Beautiful Steve !!
So very well executed ...
--Paul
That roof is gorgeous.
Can you clarify what type of tissue paper you are using? I don't think it's the same kind I'm used to as what you've used looks slightly thicker?
SteveCuster
Thanks Paul. Thanks Craig.
Craig, here is a link to the same brand I bought only they don't seem to have black anymore. I think the gray would work well also.
https://www.amazon.com/Gift-Wrap-Tissue-Paper-15/dp/B078PHC52R/ref=sr_1_1?crid=233KCTPZLLJAH&dchild=1&keywords=flexicore+packaging+black&qid=1613769227&sprefix=flexicore+pack%2Caps%2C323&sr=8-1
It seems like standard tissue paper thickness, pretty thin. I did spray it with black spray paint so that may have given it a little more thickness and stability.
Steve Custer
