Great start Jeff.....I'll be looking in.
Looking forward to your build.JerryHey Jerry, I'm looking forward to it as well. I've wanted to do a build of this kit for a while. Doug at Foscale really hit it out of the park with this one.Quote from: tom.boyd.125 on March 19, 2021, 09:51:16 AMJeff, Looking forward to your scratch build of this REA freight house.Will follow along. Tommy
Jeff,Looking forward to this one as well. Always admired the kit. If it helps here are some pictures I took of Doug's pilot model when I was at the EXPO in Altoona a few years back.
Jeff,I'll be following along on this adventure as well. I have this kit and do plan on building it one of these days. It will fit on the Summit level of the Atlantic a\and Southern RrR.Oh yes, great start.Tom
You are off to a good start, Jeff.A couple of things I noticed. For your future larger scratchbuilds Northeastern Scale lumber also does 6" wide boards which would make spicing in this case unnecessary.Secondly, I would suggest you buy yourself a good .5mm clutch pencil. I find with this I can get my window and door openings very accurate and then there is usually no need to enlarge my openings. Likewise I very seldomly find I have made then too large.Do you plan on changing up some of the roofing material? There is a lot of tar paper in this kit.Cheers, Mark.
Hey Jeff:Looks great so far. Will be following along.Karl S
In awe of your workmanship. Thanks for the running narrative and lessons.Just one small "nit" if I can. You have a first floor door that sits off to the left of the windows above it. From an architectural and engineering point, the left side of that door frame would be in a direct line with the left side of the windows above it unless there's a major interior reason for them to not line up. The stress of the windows above and their framing would not be placed off center on a door frame unless absolutely necessary.Trying to be constructive, not critical.
Great. Another how to project to study and see how it's done.I'll be following along.Bernd
Hey Jeff:I actually built that kit A while back. It’s A great building. I’ll be following your build.
