The house I grew up in
Started by bparrish, November 03, 2021, 02:49:34 PM
Looking forward to seeing the finished project,  Bob.  :)
Thank you all....
I finished the color on the brick last night but I can't get the gallery to take photos this morning.
So I'll wait a while and see if it changes its mind.
Thanx  all
So here are some shots of the brick work done.  It needs some clean up but it is mostly there.
There are five different layers of paint.    First I shot the whole thing with flat grey (cheap) primer.  Second was a layer of medium tan Polly S.  Then I change medium.  That is code for different kind of paint.  Many paints are a solvent for themselves.  If you go back and forth between acrylic and distillate base you won't plow up the previous.  Distillates are worse for this than acrylics.
Third was another layer of distillate that was sort of a maroon.  Then another layer of acrylic that was pretty orange.  Then finally a distillate that was REALLY maroon and pretty dark at that.
All of the coats after blasting it with the spray primer were dry brushed in various directions.  It gives a great multi colored appearance that really does not come well in the photos.   But here it is.
Excellent coloring and build Bob.
So I got some bench time before we leave in the morning to go see that grand kids in Portland'
Here are two photos of the ground floor with the windows installed.  These are the easy ones as the interior will not be seen so I could put glass behind and simply press the windows into the openings and secure them with a dot of superglue in each corner.
The second floor will not be so easy.    I'll need to cut the glass exactly to the window size and put the entire unit in as one piece.  Then I can case out the windows from the inside with stained strip wood.
So for now.
And another.
Back in a few days...
So impressive , the house itself but especially your building it.
Excellent looking brick building.
Beautiful work - have fun with the Grandkids!
Such a masterful job, Bob.
We lived in a very similar looking building for several years, except ours was a four-plex and we lived in the upper right section.  My bedroom was the back porch off the kitchen.  Not fun during the Midwest winters, but delightful during the summers.
Bruce Oberleitner
Dang Bob!  Another fine model.  Very Very Cool.
;D ;D 8)
Bruce.....
Now I need to figure out where to put it on the railroad.  Using forced perspective in a lot of areas it tends to look bigger than most structures in possible locations.   What a problem huh....!?!!?!?!?!?
Thanx for looking in
NKP768
Just keeps looking better and better.  Nice brick coloring.
Hey Bob:
This project is looking just great. I just can't wait to see more. I just love how you've assembled the walls to look like your house.
So I got the windows in this week.  There are some adjustments still out there but it's coming together.
This brick stuff from Monster is great.
Now on to the interior..........
