John, that is a lot of clear workbench space, I will bet it gets filled up soon.
John , that looks awful , the empty workbenches , what a sad sight  ;)
Quote from: jimmillho on January 13, 2019, 12:21:33 PM
I have already started. ;)
Quote from: Janbouli on January 13, 2019, 12:53:20 PM
Jan
Your right, I need to get them filled up again as quick as possible.
John the diorama looks wonderful.  Excellent job on those two buildings.
Wow, they surely do look fantastic. Great job on the structures and diorama, it must weight a lot.
Your latest build looks great and the water redo came out really well.
A fantastic scene, John!
I was looking back over your plan - I did some figures to work out where my 'large' layout would fit and yours is enormous!  Do all the numbers refer to pages of the thread?  It is a truly mammoth project!
Quote from: Jerry on January 13, 2019, 11:39:49 PM
Thank you for the kind words.
Quote from: ACL1504 on January 14, 2019, 08:18:46 AM
Thank you for the kind words my friend. It doesn't weight to much, lots of foam.  I would guess 30 pounds. Most of the weight is the stones I added for the scenery.
Quote from: PRR Modeler on January 14, 2019, 10:27:34 AM
Curt
Thank you - I'm happy with the water for the location on the layout.  The big surprise for me on the redo was how much the acrylic materials darkened the colors I used for the bottom of the pond.
Quote from: mark dalrymple on January 14, 2019, 02:25:46 PM
This layout is a lifetime project so yes it's big by home layout standards. The current layout is about 1200 square feet minus the areas for the furnace and workshop.  The addition that I will be getting started on this summer will be another 20 x 40 feet but more than half of that space will be crew quarters. Any future expansion will consume crew quarters space currently unapproved for expansion by the CFO of the S&S RR. ;)  CFO=Boss=wife.
The numbers that you see on the diagram are track power block numbers.  Each block of track can be turned on and off by the switches you see on the lower benchwork.  This really helps when I leave a pair of pliers inside one of tunnels and need to find a short.  It also allows me to turn off the sound to a locomotive when it's on a storage siding. The layout has 9 power districts and 120 power blocks as currently designed.
Do you have a "it's finally dry" photo of the water?
Quote from: deemery on January 14, 2019, 03:01:31 PM
Dave
Not yet, I have the diorama on the layout with the back facing me for additional work.  I will turn it around in the next couple of days and take a "it's finally dry photograph".  The pond is dry but the water in water fall area is still curing.
Looking forward to it!  I thought you might need a couple more days of cure.
