2021 Winter Build Challenge, Let's build a Jordan!
Started by Raymo, January 01, 2021, 09:03:50 AM
Raymo
Quote from: Rail and Tie on January 18, 2021, 05:36:40 PM
Nice work Dan. You can't beat the detail that is in a Jordan!
No you can't Darryl. It's amazing what they were able to recreate in HO scale.
Raymo
To get back to Jaime's question, I have these clamps that I use to paint frames and sub assemblies that I picked up from a tool vendor at a show. I held the chassis by the driveshaft to paint it. I felt it would be easier to touch up at that point.
Raymo
To start with the detail painting, I painted the bumper and the headlight bezels with Brite Silver. I also painted the tail light lens.
Raymo
I painted the rubber part of the tires with some Grimy Black. I also painted the hub caps with the silver. I also painted the radiator and fuel cap at the same time
Raymo
I chose maroon craft paint for a license plate color and dry brushed white over the numbers. I also painted the tail light Tamiya Red Clear
Amazing detail, my friend. I'm really enjoying this thread.
Raymo
Time to detail out the cab interior. I painted the seat cushions Vallejo German Camo Med. Brown. I also was able to paint the steering wheel black and painted the gauge cluster silver on the dash.
Raymo
The lower seat was painted as well
Raymo
I attached the headlight lens to the buckets with some gallery glass.
Raymo
I also attached the front wheels
Raymo
Then the rear wheels
Raymo
While that set up, I installed the floor to the cab
Raymo
Raymo
Dan,
First, I had never thought of using tube cement to hold the parts while applying the liquid.  I will definitely be trying that.  I like the way you build in subassemblies that allow for things like interior painting after (partial) assembly.  I'm not sure how this will translate to assembling a Mack or Packard truck but it should work great when I build a Model T truck.
As usual, flawless work.  Anyone that has attempted a Jordan understands just how tiny the parts are and the precision required to have an exact fit and paint separation that stands up to enlarged photos.  Thanks for the great step by step.  You have once again raised the bar.
