Sheepscot Autocar C-90 for the A&S Railroad.
Started by Raymo, June 15, 2015, 05:14:20 PM
Raymo
 At this point I've glued up the other wheels to the axles. When these have set up, I ran a sanding stick across the surface of the tires to even them up. The width of the front tires is about 15/16th of inch measured from outside edge to outside edge. The rears are about the same
Raymo
Now if you set the frame on the axles and the cab on the frame it should something like this
Raymo
You can see how the grille fits down into the frame. In this kit George supplies some plastic channel to fabricate a front bumper. I've cut two pieces and notched them to accept the front bumper. I've glued these on so they end just beyond the nubs on the frame. I then cut another piece the width of the cab and tacked it to the other piece's
Raymo
George supplies a piece of plastic tubing and some green wire to make an exhaust. Trucks of this era had the exhaust dump underneath.
Raymo
I now have attached it to the left side bottom of the frame so when it's turned over it will be on the right bottom looking forward. I've also applied a piece of wire to represent a driveshaft. I also broke the tack on the front bumper :o
Raymo
I drilled a couple holes and enlarged them to represent access holes in the bumper before I placed it back on the frame. At this point the truck should look like this.
Raymo
donatode
Raymo,
That truck sure looks good and will fit in nicely on the A&S RR. Great thread.
DEFugere
Thanks Dan for a super thread building this truck. I've always enjoyed your cars and trucks. It makes me wish this era was in my time frame for my modules. Either way I will check here for updates. You not only make it look fun but easy.
David
Raymo
Great thread! I'm watching with great interest.
Raymo
Raymo
Quote from: ACL1504 on June 16, 2015, 10:13:52 AM
Raymo,
Hopefully you have a need for coal delivery :D
Raymo
Quote from: DEFugere on June 16, 2015, 06:44:22 PM
David
David ,Thanks for following. Glad to see you on this forum. :D
Raymo
