New Lisbon station
Started by ak-milw, January 13, 2014, 09:41:51 PM
Andy,
Excellent start! I'll be followiong along with the others. This is going to be a nice station. Any colors as yet for it?
ak-milw
Tom, thanks!!
It will be the standard light gray with dark gray trim .
8)
ak-milw
Front wall of the bay window cutout.
8)
ak-milw
The side walls for the bay are done. It was to hard to cut them out of a solid sheet so I made them using four smaller pieces.
I also had to cut up two Tichy windows to make them fit the openings.
8)
Hucklebury
Cool looking build!
Is that a ginormous block of granite you are using as a display stand?
ak-milw
It is a machinist's surface plate, perfectly flat. It is red granite
Bay window area assembled, painted and attached to main building.
8)
ak-milw
The walls for the station are stucco, I will be using Liquitex, ceramic stucco for this. I did a sample board using two different shades of gray. I will be going with the bottom lighter one.
8)
ak-milw
I added a 1/32 by 1/8 basswood strip along the bottom to act as the concrete base.
8)
Bntrainmaster
Andy,
Looking good. Thanks for sharing.
ak-milw
You are very welcome Bart. Thanks for looking!!
8)
ak-milw
The end wall caps are all on using 1/32 by 1/16 strip wood. The small curved pieces were cut out of styrene.
8)
gnatshop
I like the granite block you build on -
gotta find me one of them!   ;D ;D ;D ;D
ak-milw
Hey Gnat, you can find them at any machine tool supply house. This one cost a little over $300.
8)
ak-milw
I set aside the main building and will finish the baggage room first. I added the station sign base and painted the trim. I can touch this up after the stucco is finished.
8)
Andy nice job.  Like the foundation.  Looking forward to seeing how that stucco looks.
By the way it's not snowing here in South Jersey!!!  Yet!!! :)
