Painting A Brass Locomotive for Erieman
Started by ACL1504, January 02, 2016, 06:01:01 PM
Quote from: tct855 on January 03, 2016, 09:23:45 PM
Man!  Some people have all the luck.  I hope I never get to tell a shivering story like that.  T...
Thom,
I was lucky that way once and I'll post the pictures for proof when I find them.
Quote from: martin.ojaste on January 03, 2016, 11:23:06 PM
I used to think painting brass engines was difficult/challenging; now I know better.  Great thread.
Martin,
Brass painting may no be difficult but it is still challenging. When you paint yours please post the pictures so we all can share in the process.
Quote from: ReadingBob on January 04, 2016, 06:18:59 PM
Hi Tom,
As usual....WOW!   :o  I can't even begin to imagine tackling a project like this.  It's fun to follow along though.  Thanks for sharing.   :D
Hey Bob,
Thanks for stopping by, much appreciated. It's not to difficult now, after 358 of them but I still remember how traumatized I was when I painted my first brass loco.
I love the Red Light District build you are doing. Great stuff.
I forgot to post pictures of a repair I made on Frank's loco. Does anyone know what the part in the photo below is?
Its called a Waist Sheet or commonly referred to as an expansion knee. It's a vertical sheet of steel attached to the expansion crosstie. It extends from the frame upwards to the bottom side of the boiler. This part supports the waist of the boiler. I could go into more detail but you get the idea.
Oh, the outside portion of the Waist Sheet also supports the Eccentric Crank rods.
Anyway, this was the problem with the loco not running well for Frank. It was broken and then super glued in the wrong position.
You can see in the above photo and the one below I made the repair by soldering the two pieces back together and this time in the correct position and correctly done as well.
tct855
This is really a good thread.  I just love working on brass, judging from all the great replies it seems I'm not alone.  I hope more join in.  Ok I have my favorite bev in hand and are tuned in.  Please continue...  Thom...
Quote from: tct855 on January 04, 2016, 06:54:01 PM
Thom,
Thanks again for checking in on the repair and the painting process. Working with brass isn't for everyone but it sure is for me. If you haven't seen this little thread I did a year ago, please take a look.
http://modelersforum.com/index.php?topic=1016.0
What do you think?
BTW, I'll start the painting process later this week and post the pictures accordingly. I know Frank is anxious as well.
tct855
           No I didn't see that thread.  Very kewl!  I really like the weathering a lot.  I also like the speaker setup in the tender, that's intriguing for sure.   I like it!  https://youtu.be/x5eGsAvXzP0?t=25  Thanx Thom...
Quote from: tct855 on January 04, 2016, 10:22:32 PM
           No I didn't see that thread.  Very kewl!  I really like the weathering a lot.  I also like the speaker setup in the tender, that's intriguing for sure.   I like it!  Thanx Thom...
Thom,
Thanks for the kind words, much appreciated.
I told Frank I would show him my brass melting down from the 400 degree oven. I promise after this I'll get back to posting photos of Frank's loco.
The tender and wheels were the easiest to repair.
The loco boiler and cab was a very difficult task.
Running boards back boiler barrel and cab had to be perfectly lined up and then soldered.
Piping back on prior to the cab.
After 80 hours of repairs it was time to put to together and make sure it ran properly. It did!
Now take it apart, paint and bake at a much lower temperature and then back together.
The End.
Quote from: bparrish on January 05, 2016, 06:36:49 PM
Tom...
Great stuff.
Thanx
Thank you kind sir, much appreciated.
See ya!
