SP RR
Started by sdrees, January 30, 2016, 10:28:44 PM
Twopoint2
Steve nice job on the track work so far.
sdrees
Steve Drees
SP RR
sdrees
Here are some progress photo's on the track laying.  The first picture is the track from the main line to the sawmill area with 3ea 24"-18" radius No. 6 Turnouts.
The second picture is the sawmill area with the main street commercial area, the engine service facilities and the sawmill.  I am using No. 4 turnouts in this area. Just behind the engine service facilities will be a gallows turntable.
Steve Drees
SP RR
KCS Trains
Steve,  I really enjoy watching the progress of your layout.  Great use of Sierra West kits.  Phil
sdrees
Hi Phil,
Thanks for stopping by.  I am watching your progress on that other site.  I took the Sierra West Main Street diorama and cut it on my table saw down the middle to split it up.  The sawmill is a scratch built project.
Steve Drees
SP RR
KCS Trains
Steve, I wish my bench work was as good as yours.  However, it is serving me well.  I really like your scratch built sawmill.  Phil
sdrees
This is what the track work will look like in the sawmill area.  Only the switches are glued down yet. The turntable will be where the whole is located.
Steve Drees
SP RR
sdrees
Hi Phil,
You bench work looks very good for your plan.  You don't need anything else.
Steve Drees
SP RR
KCS Trains
Thanks Steve.  That means a lot coming from you.  Phil
Powersteamguy1790
STeve:
The track work is coming along nicely. Reminds of the time I spent in HO scale (over 35 years before going into N scale) hand building and laying track.
Phil
I stopped by to check on your progress.  You are moving right along - very nice work.
KCS Trains
Thanks John.  You and Steve have been my inspiration.  Like you, I'm right in the middle of feeder wires, suitcase connectors, and tortoise switch machines.  Phil
sdrees
Attached are recent photo's of the track work in the sawmill area.  I finally have the sawmill elevation where I like it.  If you remember, in an earlier post I mentioned that I had a clearance problem under the sawmill.  The sawmill diorama is built on 1/2" gator board and 2" to 3" pink foam.  So I added a 1/2' of cork to the base of the whole sawmill area.  I also used a router to cut the gator board to add another 1/2" of clearance for an overall change of 1".  I built the sawmill before I had the plan for the layout.  There is more short pieces of track to add to the area, but I have to wait until the buildings are in their final resting place.
Steve Drees
SP RR
Powersteamguy1790
You're moving right along Steve. Nice going. 8) :)
sdrees
I recently purchased the new Walthers 90' turntable.  The supplier shipped me the 110' turntable by mistake so instead and I had to have them ship the 90' and then I returned the 110'.
Any way, it is all plastic as expected so I need to paint and weather it.  The bridge comes with code 83 rail.  I was able to unsolder the leads and am going to install code 70 rail to match that on my layout.  The bridge girders are a shiny very dark gray.
Steve Drees
SP RR
