Sewel's Foundry FSM Kit #225
Started by postalkarl, March 30, 2016, 08:16:48 PM
Thom
You better get that screw driver off the building in Dovertown before George finds it!
tct855
          That's not to far off the mark.  A couple years ago I was working on a crossover switch with George, and left a file in the gauge of the track.  With running trains cars were uncoupling and derailing.  We couldn't figure out why, right away.  I told George I'm probably going to have to walk the track, checking for a broken rail or something.  3 trains later I saw one bounce and had my ah-ha! moment!!!
Thanx Thom...
Here is a little F&SM history for you and a picture of Sewall's from a Mainline Modeler article the George wrote.
Hi John:
Thanks for the Pic.  Here's some progress photos. Building B is glued to building A. Working on the main roof. Roff is on Building B. I dry-brushed the stones with light gray. Let me know if you think they look better.
Karl,
It's coming along nicely and the walls look better. They looked good before as well.
Hi Tom:
Glad you like and also glad the walls look a little better. Thanks.
Hi All:
Got A little more work done on the roof. Cupola's and dormer is on. Here's a few photos.
It's really coming together nicely, Karl.
Hi John & Jeff:
Thanks for the compliments. Finished the roof details since my last post. Hope they look OK.
fbernard65
Karl,
Looking really good!!!
Frank
Hi Frank:
Thanks buddy appreciate your comment as always.
Mike Engler
Some nice building young man. I like the stone walls and your coloring. Are the walls hydrocal, resin, or wood? Probably not wood since lasers not used much when Sewall's appeared. See if you could lightly dry brush a little off-white in a small area you could easily fix if you don't like the effect.
Really sorry I only got to spend a few minutes with you at the Expo. In the old days we would have probably closed the saloon a night or two.
mike.engler59@gmail.com
Hi Mike:
Thanks for the post and the compliment. The walls are none of the above. They are cast metal. I will try dry-brushing with white and see how it looks OK.  Yeah sorry we didn't to spend  much tome together either. Hopefully the next time we see each other OK.
