Thanks for following, guys.  I've used a sponge to lightly put some of the Sandstone and Grey paint on the windows and doors.  The first pic shows a laser cut piece that goes on one of the walls.  This is where laser cutting really helps, it would have been a pain to build this with stripwood.  I stained it with the Hunter's stain, then the green, then grey paint sponged on.  I think it will all tie together with an A&I wash.  The second pic shows a couple of windows and a door as well as the laser cut piece fitted.  I'm going to do the A&I before the window glass is applied, but I need to size and cut the window glass first.
Twopoint2
Looking good Jeff.  Thanks for all of the progress photos.
Thanks, Jan, Mark and Jim.   :)  I've cut out most of the windows.  I'll show how I install them later today (I hope).  I've applied a black wash to the walls.  I made up a new batch of A&I, one teaspoonful of india ink (5ml) to a pint (474ml) of alcohol.  While mixing it, I noticed the "snap cap" leaked, so I poured it into an old, nearly empty alcohol bottle.   :o I used the wall which will be in the back of the building when place on the layout.  I have had problems in the past with the A&I lifting the paint, and it happened again here.  This didn't occur on my last build, because the paint was dry for 6 months (!) until I got back to it.  I used Vallejo black wash instead.  This is very concentrated, and I tried various dilutions and ended up with about 2ml in 30ml of distilled water (I think).  I put a couple of drops of Liquitex Flo-Aid in this as well. After putting it on, I thought it was way too dark, but after letting it dry overnight, it's pretty good.  In the pic, the upper pieces have the Vallejo (I needed a second coat on the bottom of the "plywood" wall.  The lowest wall has A&I to the right of the window (you can see where the green came off and onto the brush and thence the wall).  The left part of the wall has a more concentrated Vallejo wash--too dark, I think.  I should know by now to start light and add more layers of wash if needed.  Oh well, I could always use our new modeling philosophy on mistakes.  "Cover it with a bush!".   ;D
Here's how I do the window "glass".  I use my calipers to measure the inside of the window (pic 1), then I flip it over and use the other side on the clear material.  Use an Xacto knife to make a mark even with the edge of the caliper.  Do this a few times along the clear material.  Note that the clear material is aligned with a line on the cutting mat, so I know this edge is straight.  The next picture shows my straight edge and a leather glove, just in case I slip with the knife.   ::)  Take the cut strip and test it to see the fit (Pic 4).  Then mark how long a piece is needed  for the upper sash.  Cut this, see if it fits, then mark it with a piece of tape (so you don't lose it, don't ask  :) .  Put a dot on the top of the tape to keep the orientation correct. (Picture 5).  Back after the break.
Position the glass on your Chopper, adjust the stop and you should have it then set to make windows.  I "Chopped" out the first one and it was slightly long, Probably from pushing against the stop.  I readjusted the stop and the next one fit fine.  Cut out extras, because you will lose one.  Or two.  Or more. ;)  I then clean them with Windex and a lens cloth to get the fingerprints off them (picture 2) .  I then attach them with Future floor polish.  It dries clear, fills in any scratches on the window, and I don't have to worry about getting glue on the panes.  Grab them with the cool suction cup tool, dip them in the Future. (picture 3). Touch the edge to a paper towel and place the window in the frame.  Let them dry.
Great progress!  I've heard of using the Future floor polish for other applications, but not for gluing in the windows.  I'll have to give that a try.
The build is looking very good. The window install seems a little labor intensive for me but I'm sure it is worth the effort in the end.
Hi Jeff:
Coming along nicely. Love the white peeling paint with the green trim. Keep up the great work.
Thanks, guys.  Yes, Tom, it's kind of a pain to do it this way, but I've not had good luck with the Canopy glue nor the gallery glass.  I seem to get "bubbles" in the glass, or it slops on the front of the window frame.  That, said, I did do the small window with gallery glass and it turned out OK.   ::)  One of the glass panes "moved" and I didn't notice it until after it dried.  I pried it out and replaced it with a "tin sign" cut to fit the frame (picture one).  Next was cleaning the resin bases.  Some of these had sticky stuff (think transfer tape sticky) on their bottoms.  I removed most of this with goo and purple "super clean".  But it's on the bottoms and it won't really matter.  I then painted the centers with Rustoleum textured tan paint and then masked them and painted the edges with red primer to represent the bricks.  I then blobbed on some black wash in some areas of the bricks to break up the monotony of the color.  (pics 2 and 3).  There was a small spot where the tape pulled up the tan paint--of course right near where the garage door is  :( , so I overpainted it with some bleached titanium.  Then A&I was used to wash all the "concrete" surfaces down (Picture 4).  Then I used Robert's Mortar for the mortar lines.  Dab and brush it on, let it dry for a minute and wipe off with your finger.  I wipe it off lightly to leave some of the mortar on the bricks.  (Picture 5).  Next up, putting the walls together!
It really looks great Jeff. I'm enjoying the thread.
Your walls look great and I love the mortar between the bricks.
I've not had good results with Robert's Brick Mortar. I'm guessing its the Indian and not the bow and arrow.
Thanks, guys.  It's starting to look like a building!
