Challenge Build - Pawn Shop and Liquor Store
Started by jrmueller, October 03, 2016, 07:23:13 PM
jrmueller
Finally underway after some unscheduled delays.  I usually unpack all the materials to see what I am dealing with in terms of the various materials.  I have to admit that I initially don't read all the instructions; usually I skim to see if there is anything unusual.  More to follow in a day or two.  As you can see, I need to clean up some work space.
Jim Mueller
Superintendent(Retired)
I'll be following along on this one as well.  I have it tucked away on the shelf.
Hi Jim:
That's a cool kit. Lots of great detail. I will be watching.
donatode
MASIGMON
Jim,
Add me to the list of watchers/lurkers.
NEMMRRC
jrmueller
So am I!  There keep seeming to be delays in moving forward on the build.
Jim Mueller
jrmueller
OK here we go finally.  The first thing I do is identify the pieces that require bracing.  Then I use the sanding jig I got from MicoMark to square up the edges. Next I glue the bracing using Titebond III that has proved to be my glue of choice with wood pieces.  I make sure the bracing is square with the edgies.  Each pieces is weight to prevent warping.  There are lots to brace so I'll be back later.
Jim Mueller
Raymond Gardner
I'll be checking this one out! Love Fos Scale!!
jrmueller
Believe it or not but I have made some progress.  It just seems so many things get in the way.  Thanks for "giving me a nudge."  Jim
Jim Mueller
