Petite Properties
Started by madharry, November 30, 2016, 12:35:13 PM
madharry
Here is the completed model, I have named it after my late sister - "Diane's Ladies Fashions".
The display window will be lit from below by a LED and features three Preiser figures "striking a pose"!
donatode
Very nice and neat work Mike.
madharry
Thank you Donato.
Here is the latest - The Lumbard Arms.
I named this after by Mother-in-Law. The model has a full interior which will lit by a LED. I found a coat of arms for the Lumbard family and reduced it in size on my photocopier to fit the model.
The shingles/tiles are by RS Laser.
madharry
Time to start another one. This one will be the "Worker's Cottages". I decided to experiment with the Redutex texture sheets, this time their Dry Stone/Flint. After the carcass was glued together using PVA I cut a piece to fit the building wrapping it carefully around the sides. Now I need to cut out the window and door openings...
madharry
Here is the wall with all the opening trimmed out. The Redutex material is very forgiving. It is very thick to cut out and I will now need to change my blade for a new one as it has made it very dull.
The stone/flint finish is very common in parts of rural Britain and I think the texture sheets are very realistic. Once completed I will weather the surface with some chalks to tone it down a little.
Hi Mike:
This is interesting stuff. The Lumbard Arms is great. The workers cottage looks really interesting. I will be following along.
madharry
Thanks Karl, yes it is interesting what you can do with these kits. I'm really enjoying making them.
madharry
Here is another set of terraced houses. This time I have used Redutex Dry Stone Walling to cover the model.
Mike,
Great job, I really like what you are doing.
madharry
Thanks Tom, I took them to the MRC last night (they are my severest critics) but they passed with flying colours.
I  intend adding soffits, guttering and drain pipes when I can source the materials..........
madharry
And the town keeps growing.............
Here are a couple of terraced houses nearing completion and three more carcasses glued up and awaiting their turn.
What is so nice about these kits is I can decide how to treat the wall surfaces on each on every one.
Hi Mike:
Very nicely done. The top one is coming out great.
madharry
Thanks Karl I was hoping to get that one finished today, but as it is mild here at the moment I had to clean both our cars....huh.
madharry
Here is the smaller carcass - a little cottage. I tried something new for me. I sanded the MDF walls and then painted them with PVA.
Once dry I applied a thin skim of wall plaster on to the walls. I found some ready mixed in my local £ store.
After the walls had dried overnight I scribed a stone wall effect onto the plaster. My first attempt but I am learning. Once this is fully dry I will dry brush the stones with various beige shades.
madharry
Here is the finished stonework.
