Mclachlan Hat factory
Started by fsmcollector67, December 08, 2016, 10:18:05 AM
fsmcollector67
Marty,
The old Basswood is pretty tough, even on one end, I have only maybe an 1/8" between windows, and the wood held up. Did not even warp real bad when I stained it. I probably will have to have a mortgage on this property.....thanks for the comment.
Loren....
9 Fingers Loren.....
Twopoint2
Loren great job on cutting out all of the windows.
fsmcollector67
Jim,
Thanks....It was not as bad as I had thought.....
Loren...
fsmcollector67
Hey All....just a few small things today, First I did a test for the sidewalk, just have to cut back on the cracks....came out pretty good? Also got the smokestack pretty much done, still trying to find that perfect brick painting combo, it will have to do...till next time ....
Loren...
fsmcollector67
Howdy All...Back again, been awhile. I have been busy working on staining, and bracing the wall sections. I also have been working on the 199 windows as well. I have a couple of wall sections glued together. The small items, are some things that I am going to cast for an upper floor interior. The cone shape item is a copy of a machine used to form the hat bodies. On a side note, earlier this week I was lucky enough to be able to acquire the fine kit pictured below. The original owner had never even opened the box that it was shipped in from SRMW. Till next time....
Loren...
Loren
The build looks great - and congratulations on the future build.  I hope you will share the brick roundhouse build with us as well. Bob sure produced some great kits.
fsmcollector67
Thanks for the comment, the SRMW kit, will remain sealed, until it is time for me to part with it. 10-20 years hopefully. A future generation can still have it to build.
Loren..
 Loren, your large mill structure is really coming together. It will be a very impressive model when completed.  8)
Tommy
Loren,
Just getting caught up on the factory build. Beautiful work and the structure is very impressive. Well done, very well done.
fsmcollector67
Tommy, Tom,
Thanks for the great comments....
Loren...
fsmcollector67
Hey All,
Just a small update today....I did some brick work. The first photos are of the old boiler house, this I painted with Bragdons used brick, to give a more of worn old look. I used Georgian clay, Heritage brick, Brick red for the individual brick colors. The mortar was done with Bragdons as well. The small structure is the base for the smokestack. This was painted with Brick red craft paint, and same individual brick colors mostly as the other. This I wanted to represent newer brick. Getting a little better at brick work, but still think I can do better. Just have to find that perfect mix.....till next time...
Loren...
fsmcollector67
Howdy all...small update today, did a couple of scratch doors. The one on the boiler house is wood, and the metal freight door is made from plastic sheet, and strips.
Till next time...
Loren...
Great looking brick corners Loren..... 8)
rpdylan
I think the brick work looks fantastic! I like the way the metal door came out. Very nice work
Bob C.
fsmcollector67
Greg, Bob,
Thanks for the comments...Greg, it was a real pain to get those corners to as close to 45 deg. Had to use a little wall patch to fill in, and then scribe the lines again.
Loren..
