I wet this down with lots of Alcohol to make a wash.
I then painted it on the wall section with a big brush to blend all the colors together.
The picture above is early on - I used lots of alcohol to darken the mixture and get more of the brick color and then blotted it dry with a paper towel.
This will be my starting brick color that will now be heavily weathered with grit, grime, oil etc. to get that grey color that Dave talked about above.
I have one issue to report.  Since I was using a technique on wood that I usually use on plaster and resin the alcohol warped the wood because it was applied on only one side.
A quick application of clear alcohol to the back side of the wall. Followed by weights as it dried solve the problem.
Here is a picture of the brick cut to size and glued between the inspection pits.
There will be brick between the inspection pit and the dividing wall between the machine shop and the pit area.  I need to do some more research on my crane installation before I can add the wall.
A quick update:  Work on the S&S RR has come to a temporary halt while I spend time with my wife Amy (CFO of the Superior & Seattle).  Amy ended up in the ER with appendicitis on Tuesday. All is well - we are hanging out in a hospital room while she recovers from surgery and receives IV antibiotics.  I have been making use of my time catching up with my picture sorting from the Narrow Gauge Convention (see 2017 Narrow Gauge Layout Tours) if you would like to take a look at the pictures.
I got back into the train room very a little while, yesterday.  I made 20 more windows for the Locomotive Works and started building the roof sheds.
The perfect workbench picture - everything in it's place.
Round one of weathering the inspection pits.  It's starting to look like somebody has been working on steam locomotives. I'm assembling the overhead crane so I can determine where the dividing wall will go. Then, I can complete the brick floor on the right side.
That floor is looking great!  So glad Amy navigated the hospital experience well.
