If you look down in the hole for the Brambell's build you will see an abandoned line that ran to a hidden yard on my previous layout. I was originally going to keep it for this layout but the maintenance was just to difficult - so I terminated  it with this scene.
The next step is to test all the LED's one more time before access is from under the benchwork. ;)  I bought the tester from Slim at the EXPO - great little tool.
Next step was to add the structures and make sure they were level.
Once the structures where in place I started to add the land forms to blend them into the other scenery.  I start out by filling all the holes with wood, old cards from hotel stays, clay,  and paper. This needs to be sealed with thick glue so the thinned glue that I use in the scenery steps don't run out on the floor.  I then add a base layer of beach sand. Here are a few build pictures of this process. After the sand glue mixture dries it will be time to add the final scenery materials.
http://Houston we have a problem.  I reposted this picture three times and get a blue box with a question mark. When I posted the same picture below it works. ??? ??[/img]
EricQuebec
Just incredible...
Always a pleasure to follow ths thread.
Eric
Quote from: Lynnb on April 28, 2018, 09:40:01 AM
Quote from: S&S RR on April 26, 2018, 07:59:02 AM
The next generation of Engineers is starting to take over on the Superior & Seattle. Running trains is serious business.
Cute, I have a few years before grandson will be running trains.
Nice job on the slime water, wood looks great too.
Lynn
Thanks for stopping by my Grandson is going to be 2 on Sunday. He knows buttons and knobs make things happen and does a great job. He watched his brother and Grandpa and just copied what we did.
