Dennis Bourey
Dennis Bourey
dpbourey@comcast.net
Lake's Region RR
(Happy Modeling)
Hmmm...  I would have used my biscuit joiner for those butt joints on the helix arms, and then put a piece underneath.  But in part that's because I happen to have a biscuit joiner and big pile of biscuits to use :-) :-)
Quote from: deemery on May 06, 2019, 04:28:22 PM
I prefer the lap joints with plywood, Dave.  ;)
Quote from: PRR Modeler on May 06, 2019, 05:55:42 PM
Very nice job John.
Thank you Curt - I need to take pictures as I build this because it's all going to be covered.
I made a little more progress today. Added the front piece of plywood to the upper level for setup and started the lower level benchwork behind the sofa.  Once I have everything setup and in place I can move the sofa to work on the track work.  Okay, so the starving artist painting is coming down tomorrow.  I bought that for my apartment when I just got out of college and had no money. I've found a place to hang it for a lot of years but I think it going to come down for the layout.  I wonder what it's worth. ;)
Really looking good John.  I like the bench work.
Dennis Bourey
I LOVE IT WHEN A TRAIN TAKES OVER THE HOUSE !!!!!  ;D
Dennis Bourey
Lake's Region RR
(Happy Modeling)
Quote from: jimmillho on May 07, 2019, 10:54:09 AM
Thank you for following along. I using 2x4 for the frame work - overkill - but much cheaper than by 1 x 3 pine. I will be able to climb on top of this - if required.
Quote from: DennisBourey on May 07, 2019, 12:06:48 PM
Dennis
Don't let the CFO hear that! Only my negotiated space. ;)  And I'm only using my golf money.
Dennis Bourey
My CFO says as long as her craft room is not touched. I'm good lol. Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
Quote from: DennisBourey on May 07, 2019, 12:26:46 PM
Keeping the CFO happy is the only way to run a railroad.
Today, I spent most of the day laying out the top area above the helix.  This area will have a large roundhouse and turntable. I tried a number of different designs - starting with the one I settled on in the computer. Once I got it all mocked up full scale on the plywood I didn't like having turnouts and turntable areas that were out of reach if something went wrong.  By shifting the turntable to one side I gave up some outside storage tracks but gained some roundhouse stalls.  I also moved the turnouts farther back so I could reach through the wall to retrieve any locomotive that got hung up on a turnout. If you have a turnout someone is going to run through it without aligning the points. Here is a picture of the design mocked up.  If I still feel the same way about it, after reviewing it again in the morning, I will be implementing it. The Roundhouse will have 3 stalls, then a gap for the feeder spur, and then another 10 stalls. So technically there will be two roundhouses served by one turntable.  I have seen pictures of many prototype roundhouses with this type of design and have always liked it.  I will be scratch building this roundhouse using brick walls that I purchased from Monster Models before they went out of business.  I should mention that the last loop of the helix that you see in the picture will be below this level when it is installed.  I clamped it in place above the roundhouse level so I could mark the cuts I need to make for clearance.
If this design survives the morning after test, I will be cutting a hole in the wall tomorrow. ;) :o
