Today, I got on a roll with the Mackenzie build.  I finished the bracing on the main structure and finished scribing the concrete wall section. Then I started gluing the concrete wall sections to the base board. I made a few minor changes to make the wall sections fit the location on my layout. I also added a wood section that will help fit the build into the layout. This following few pictures describes the build sequence.
Final location established.
Gluing the concrete wall sections to the baseboard.
Time to let the glue dry - back to the Jacob's build.
Coming nicely, I'll be following along as usual.
Excellent job. I look forward to it coming together.
Quote from: jerryrbeach on May 30, 2017, 07:22:48 AM
Hi Jerry
Thanks for following along and the kind words.
Today, I decided to tackle the trestle radius problem that I posted a few weeks back.  I have been dreading this job - I hate redo's.
Just to remind everyone I got to cute with an S curve between the two Mt. Aiden trestles and have had some problems with derails with the big steam locomotives. I need to remove the S curve - even though I stuck to a 28 inch radius and have a 3 inch straight between the two radii - it just to much for the big guys.
So today, I removed the track off the small trestle without having any problems with damaging the trestle. I have a plan on the repair - but what I didn't do is take a picture.  I'm going to be working on an outside project for the next couple of days but when I return to the layout I will take some progress pictures.
I managed to get a few hours at the workbench this morning before I started all my outside chores.  Added the support pilers for the structure on the Mackenzie build.
I also applied a coat of primer to the cement work.
