Build Challenge 2018 Republic Locomotive Works American Flag Company N-scale
Started by Janbouli, January 02, 2018, 03:56:54 PM
Thank you Tom and Curt, the walls might be large for N-scale , those windows are not and the sashes are the thinnest I have ever worked with that don't break.
Glad to have you along Mark
Took me about an hour to install the lower sashes and another hour for the casings.
I don't like the look of styrene window sheets, and using some kind of clear drying glue is also easier, just carefully fill the gaps by spreading glue with a toothpick.
I used this tacky glue , went well for these tiny windows but I am going to order some Micro Klear for when I have larger windows to do.
Next up was assembling the floors and foundation.
These will be almost impossible to see once the building is done , but I know they're there.
I painted the roof black and then stuck the lasercut tarpaper onto the still wet paint.
The roof and floor sub assemblies.
Painted the foundation Polyscale Concrete and smeared acrylic textured paste called Beton Effekt Paste I got at a German craftsstore onto the paint , I used a bit of force to smear it to make the somewhat too coarse texture a bit smoother.
Now  how to assemble the walls without bracing, not so easy because clamps and such will likely break the walls. So I used magnets and my magnetic board jig , as you can see in the next photo's.
madharry
Those are some serious weights and clamps Jan. Nice modelling!
Mike :)
jrmueller
Jan - clamps, weights ,magnets and metal tray are in use as I assemble the main walls of my Cundy Hotel.  Anything I can lay my hands on.  Jim
Jim Mueller
Superintendent(Retired)
Quote from: madharry on January 10, 2018, 04:49:20 AM
Mike :)
Thanks Mike , those weights aren't that heavy , the building is that small  ;)
Quote from: jrmueller on January 10, 2018, 08:12:00 AM
Agreed Jim , can't have enough of these tools.
Jan,
Great progress on the structure. Enjoy following along on this "N" scale adventure.
donatode
Janbouli great work! Amazing what a great modeler can do in such a small scale....amazing!
Quote from: Donato on January 11, 2018, 01:07:56 PM
Thank you very much for the kind words.
