Magnuson Municipal Building
Started by ACL1504, August 12, 2018, 05:10:44 PM
I used rattle can Tamiya Light Ghost Grey, #AS-26, for the initial coat of paint.
It turned out darker than I thought it would/should be but will leave it for now. I think it has a very slight tint of blue in the color.
I may end up repainting it with Floquil CN Gray or Grime.
I don't plan on any interior lighting or details for the kit.
The color looks really good to me in the photos. You note it seems a little dark.  I suppose if you are eventually adding weathering and washes that they could darken it even more, so perhaps that is a concern.  Looks good so far, though.
You're right about the color Tom, a wee bit off, but easily corrected.....good looking city hall.  8)
Bruce Oberleitner
Nice looking Build Uncle Tommie,
I'm going to have to write down your ideas on cleaning the sticky goo off magnuson structures and that trick about using brass tubing to brace the thing.  Brilliant!
;D ;D ;D
Howdy Tom,
Nice build for a tricky kit.  Can't wait to see the finished structure.
Mike C
My current build is the Water Tower and miscellaneous rolling stock .
Quote from: Opa George on September 02, 2018, 08:24:12 AM
George,
The photos have been lightened and it makes the building lighter. I will be adding weathering but I'll need to repaint it to a lighter grey.
I appreciate you following along.
Quote from: GPdemayo on September 02, 2018, 09:13:53 AM
Greg,
Yes, as you saw a few Saturdays ago, it does look bluish. I got it repainted this morning and an update will follow later this afternoon.
Quote from: Bruce Oberleitner on September 02, 2018, 12:43:38 PM
;D ;D ;D
Cousin Brucie,
Thank you, much appreciate the comment.
Goo removes a lot of stuff including decals. The square brass tubing is the best solution I've used in getting the walls straight.
Quote from: friscomike on September 02, 2018, 02:54:10 PM
Howdy Tom,
Mike C
Mike,
Thank you, very much appreciate the feedback.
And, good to see you, it has been quite some time. I'll be working on the kit in the next week and hope to get it finished.
In previous posts, I've mentioned how the building has a blue tint or hue to the sides. Also, as mentioned I used Tamiya Light Ghost Gray for the first color.
This morning I resprayed it the building with RUST-OLEUM Auto Primer. After about an hour it was dry tot he touch.
The next two photos show you how it looks in the layout lighting. The photos weren't lightened as before. This is the Tamiya color.
I think in the next two photos you can see the Rust-Oleum on the front right and the Tamiya on the left. There is definitely as  noticeable difference.
Grey on the right and bluish grey on the left.
The next two photos show the Rust-O paint in Grey Primer.
Now I'm ready to paint the window and door trim.
Quote from: GPdemayo on September 06, 2018, 03:16:10 PM
Much better..... :)
I am forced to agree with Greg.......although, I think it looks great anyway.
