FOS Bandits Roost
Started by Opa George, October 14, 2019, 08:05:32 PM
Looking good, George.
The timber-work beneath the flat roof will make a nice touch, although it will make the building leaky.  Maybe you will need to address that in further weathering?  An exposed patch over the front wall with corresponding rot in the ceiling over the forecourt and water stains down the wall?
Cheers, mark.
Mark, thanks for the extra weathering ideas for my bad roof.  I like them and will be adding a little more rot to the front ceiling and wall.
Below is the building with roof paper installed but not yet trimmed.  I allowed two distinct bare areas on the roof where the tar paper blew away.
Below is the same after some trimming, cutting away, tearing and weathering. I also added a Charlie Chaplin movie bill to the wall.  The image is not sharp, so I will post a few better views after I get the rooftop sign built and installed, which is the next step.
--George
Nice weathering on the roof.
George,
It's so horrible and nasty looking it looks fantastic. Well done.
Todd W.
This kit is coming along fantastic George!  You always do killer work!  I love following your build threads!
Build Cool Stuff
Modeling your way, it's your world.
http://wileysscalemodeling.com and The Bench Time Podcast
You can also follow us on instagram, facebook and youtube @wileysscalemodeling
Thanks, Curt, Jerry and Tom.  I love that comment, Tom. This really resembles the grungy corner garages of my childhood. Todd, your support and comments are much appreciated!
Only had time for a bit of modeling, so I added the rooftop sign.  It will need some weathering and streaking.
We're advertising tires, belts, oil, batteries, with no access to the interior for a vehicle. So apparently all of the work is done outside in the alleys alongside the building. This really DOES resemble a few of those tiny corner garages I remember.  Yes, indeed, this is going to be a hoot to model all of that going on!
--George
Can't really add other details until I start building the base for the entire complex of structures, so here is the gas station pretty much done, next to Vallon Paint and the burger joint.  I added a Bollinger Edgerly "Skanky Yankee" Gas Station Attendant, currently holding up the front porch column while he waits for a customer or lunchtime, whichever arrives first.  Now I need a name for him.
Here is the other side of the gas station with some Rusty Rail junk castings to keep it from looking lost.
But now I can move on to the Livery building. Doug Foscale describes this as another simple, four wall structure, which it appears to be from the wall pieces.  The walls are not on the larger wood sheets, but rather may be found in the small plastic bag of miscellaneous wood walls.  I also located the roof, the foundation, and a very small porch base.  Everything is laid out in the picture below prior to bracing.
I have them braced and drying. Will post more tomorrow.
--George
Thanks for the support, Curt.
I also discovered the gas station attendant's name is  Otto "Hub" Kapp.
--George
Great work on this build George!
JimF
Really cool, George, Coming along nicely, as all your builds do.
Thank you Mark, and thank you, Jim.
Here are the Livery walls with some distressing using a file card, then a welder's brush, then a wash of A&I.  The doors are sponge painted with white acrylic paint.
For wall color, I chose an acrylic "Deep Wine."  It is a very dark red, but I dry-brushed it on and it stayed relatively light with a washed out look.
Above is one of those weird and rare mistakes in the instructions. I added corner trim per the diagrams, but only after it had mostly dried did I realize that the high (front) end of each long wall did not need it, since corner trim is also applied to each side of the front.  I was able to remove it without a great deal of trouble, fortunately, and sanded the edge smooth.
--George
George,
Great job on the walls, looking forward to seeing the Livery come to life.
Bruce Oberleitner
Looks great.  I love that washed out red color you where able to create for the structure.
