FOS Scale Models "Oyster Hill" HO kit #200
Started by madharry, November 14, 2020, 07:20:47 AM
Hello Mike, you're off to a great start. Can't wait to see what you do with this kit. Good luck with your move, it's nice that you don't have to do it during the holidays.   Jeff
madharry
Thanks Curt, Jeff and Mark.
Continuing.................. Here are the walls of the board by board section. The rear wall will not be seen so it is not covered.
madharry
Continuing........... the basement walls coming together...........
madharry
Continuing................. the foundation for the main building is made of card which I painted with a concrete textured paint.
madharry
Continuing.............. walls erected on the board by board storey.............
madharry
And onward................ the painted and detailed walls of the main section..............
madharry
And on we go................. walls erected. I used superglue here and at least five hands to get them glued together...............
madharry
Onward............... the foundation and the main building............
madharry
Glued together...................I used Aliphatic Resin Glue here as it was tricky lining up the card walls with the wooden ones...........
madharry
The second floor of the smaller building coming together..........
madharry
The stone basement together with the first floor....................
madharry
And the second floor is added..................
madharry
Side view................
madharry
The tower, sheds and "bump outs" coming together...................
