Here is a very good look at the frieze board trim from the top. Nice and neat.
I plan to add corbels to the frieze boards just below the trim.
You can also see the two laminated boards from this angle. There will be a top plate so this detail won't show.
Done for today.
Howdy Tom, nice miters.  The flat iron structure is coming together well.  Have fun, mike
Tom, two good ideas here on cutting out the ceiling and for cutting trim pieces using the walls as a guide.
Nice clean work Tom! That had to be a pain notching all those timbers to accept the floor?
It's really nice that you show all of your individual steps with each new addition. Sometimes when doing an article I don't cover everything, such as normal procedures though. It makes for a lengthy build, but you seem to know what you're doing so I won't babble on here. Nice modeling.
Quote from: friscomike on February 07, 2025, 07:25:47 PMHowdy Tom, nice miters.  The flat iron structure is coming together well.  Have fun, mike
Mike, Howdy,
Thank you kind sir and I'm still having fun.
Quote from: Rick on February 07, 2025, 07:32:14 PMTom, two good ideas here on cutting out the ceiling and for cutting trim pieces using the walls as a guide.
Rick,
Thanks for stopping by and commenting, much appreciated. Cutting the trim this way removes all doubt about the angle to cut.
Quote from: Philip on February 07, 2025, 09:11:15 PMNice clean work Tom! That had to be a pain notching all those timbers to accept the floor?
Philip,
Thank you. I just marked the braces and then made a little notch test it as I cut the notches.
Quote from: Pennman on February 08, 2025, 02:31:17 AMTom,
Rich,
Thanks very much. I enjoy the SBS narration on the builds but I try to keep it short and to the point. I don't like to read a screed when reading others.
Beautiful job on the build Tom. You always have very precise cuts.
WOW!!!!!! :o  That is one tight corner on the angle there, you sure you want to hide that?
Great progress there, I to am glad that you are doing this step by step, lots to learn on this thread.
Tom some of the finest cuts I've ever seen!!
Your attention to detail is amazing!
Quote from: PRR Modeler on February 08, 2025, 12:24:51 PMBeautiful job on the build Tom. You always have very precise cuts.
Thank you Butty, much appreciated. Pam said I should have been a surgeon. Trouble is I cut to many classes at UF.  8)
Quote from: elwoodblues on February 08, 2025, 12:44:15 PMTom,
Ron,
Thanks very much for the very kind compliment.  I enjoy the step by step process.
Quote from: Jerry on February 08, 2025, 01:06:04 PMTom some of the finest cuts I've ever seen!!
Jerry,
Thank you also. The details are important in some areas of a build. This one has plenty.
