I added the top plate to the frieze and frieze board trim. However, this time I wanted to see if I could get a perfect fit on the odd angled corners.
I turned the structure upside down and used the inside of the wall to trace the top plate angles. The pencil line represents the inside edge of the roof.
I darkened the photo a little to show the pencil lines better.
I left the rear edge of the roof panel longer than I wanted as I haven't determined how much of an overhang I want.
I glued a 12X12 to the top of the braces to create an angle for the roof to slope backwards.
The 12X12 was to much and it created more of a slope than I want.
To make an adjustment on the slope, I'll add strip wood to the top of the rear wall section.
When I determine the correct size strip wood, I'll stain and paint it prior to gluing it to the top of the rear wall.
Diet Pepsi time, back in a few.
I drew the lines for the top plate template on a spare piece of cardboard.
I stained and painted the top board and placed one end on the outside edge of the pencil line. I used a new single edged razor blade and cut the board on the horizontal line as shown below.
Quote from: PRR Modeler on February 14, 2025, 04:18:58 PMThat's great attention to detail with the angled roof.
Thanks Curt, it had its challenges but it is turning out as planned.
I then placed the board on the outside edge of the horizontal line.
I then trimmed/cut it flush with the angle of the board on the left keeping the angle true.
I used the same method with the short board on the right in the photo.
I then glued the three boards to the top of the three walls. When dry, I used painter's tape to cover the top.
I painted the back of the frieze board with full strength Floquil Weathered Black. I made another test fit of the roof pane.
Here is how the top plate board looks from the top.
Here is a close up of both top plate angles. I'll call this the perfect fit with no glue filler.
This method worked better than gluing and then trimming once a board/trim is on the model.
Done for today.
Mr. Critter
