Winter Challenge 2024 - Flat Iron Corner Building - Tom Langford.
Next I'll work on the two main lower windows and the windows on top. I'll use Evergreen styrene strips to frame the windows.
Done for today.
Looks like I got here just in time to watch you build up the storefront.  I find the storefront to be the biggest reason to buy a laser kit.  I'm really looking forward to watching how you do this so I can apply what I learn to building storefronts from scratch, instead of relying mostly on laser kits for these parts of my structures.
Needless to say, I'll be following along even though I got here late...
Quote from: jerryrbeach on December 02, 2024, 09:43:37 AMTom,
Jerry,
Happy to have you along on this one. You may find the next several post interesting. Multiple layered storefronts are a challenge. Laser printed ones from kits are very nice and all the work was done by the kit manufacturer. Since this is a scratch build, I'm going to do most of the work.
With the exception of KC's Workshop corbel columns, it is all cut from a file folder.
Again, thanks for taking the time to watch this build.
Doing layered storefronts might be sufficient justification for a Cricut or similar machine  :)
Okay, I tried something and didn't like what I did. So I did a do over.
In the third photo above you can see I cut the two end doors as separate doors. My idea was to then cut the center windows.
Well, I decided to build the overlay as one whole piece that fits over the base.
The next two photos show the new one piece overlay. I cut the bottom trim and started cutting the window openings.
All top window openings now cut out.
Quote from: deemery on December 02, 2024, 04:59:41 PMDoing layered storefronts might be sufficient justification for a Cricut or similar machine  :)
You are correct but, I don't want to invest in one. I'll just stick to the old fashion was of doing it. For now anyway!  8)
The next photo shows my original drawing on top. The middle piece is the base and the bottom the overlay.
I used the overlay to outline the windows on the base.
I used a metal ruler to draw in smaller window opening. This will give me a little material on the base that represents framing.
I then began to cut out the smaller window opening.
The next photo shows the overlay now finished. Overlay on top and base on bottom.
Taking a Diet Pepsi break, back in a few.
I have the two pieces together in the photo below.
Here is how it will look with the corbe3l columns in place. I think the details of the two layers will look much better when painted and weathered. That will be next.
Done for today.
restocarp
That looks great, Tom! All of those little cuts!   :o  You have certainly earned that Diet Pepsi today!
Matt
Looking very nice, Tom.
Some very fiddly work executed extremely well.
How frequently do you change your knife blade?  Are you using X-Acto #11, or maybe scalpels?  That's a lot of very finicky work.
EricQuebec
Very nicely done.
Usually when I do this kind of work, I work only with stripwood, on a 1/32 basswood base,
I like doing that :)
Eric QUebec
Jim Donovan
Looking great as always Tom. Like I said, if I could model like you I wouldn't need a laser that is for sure. Really impressive.
Holland & Odessa Railroad
