Quote from: Larry C on March 02, 2025, 08:19:02 AMTom I'm always amazed at your attention to detail and your precision. I may have to get me one
of those Choppers; minus the cuts of course.
Larry,
I appreciate you stopping by and your compliment is kind and generous, thank you.
The Chopper doesn't come with cuts. I supplied that on my own.   8)
Since there is no AC in this structure, I decided to add screen doors over the exterior rear doors.
I used a Tichy door, turned it upside down and traced the outline on a file folder.
I used a metal ruler to line in the inside of the door and horizontal brace.
Using a new #11 blade, I started cutting out the door. Yes, I know it looks like a window at this point.
I test fir it over the door and then made two additional screen door frames.
Not sure what I'd call this material but it is a ribbon like material and looks perfect for HO screens.
I got this roll at Jo Ann's Fabrics. This roll will last a life time.
I cut a small strip off the roll. I used a toothpick to thinly spread some yellow glue to the back of the frames and glued them on the fabric. I used a weight to hold them down overnight until the glue dried.
Here is a look at the rear of the screen door.
I used a new #11 blade and trimmed the screen around the doors.
I forgot yo mention that I painted the doors first with Floquil Antique White and when dry, dipped them into the Hunterline LIght Gray A&I staining ink.
The screen doors were weathered with chalk powders and the sprayed with a flat sealant.
The screen doors were then glued in place.
Done for today.
Tom, I think that material is called tulle.
Screen doors look good.
Hello Tom, your scratch build is coming along very nicely. I'm enjoying the many layers of detailing that you are adding to the structure.
Quote from: Rick on March 02, 2025, 06:11:03 PMTom, I think that material is called tulle.
Rick,
Yes, it is a Tulle of sorts. Thanks, I just couldn't think of the name.
Thanks also for the comment.
Quote from: nycjeff on March 02, 2025, 10:04:56 PMHello Tom, your scratch build is coming along very nicely. I'm enjoying the many layers of detailing that you are adding to the structure.
Hey Jeff,
I appreciate you stopping by and posting your comments. I'm getting near the end for sure.
