Quote from: restocarp on December 02, 2024, 06:07:20 PMThat looks great, Tom! All of those little cuts!  :o  You have certainly earned that Diet Pepsi today!
Matt
Matt,
Thank you and yes, there were a lot of little cuts. It was a two Diet Pepsi day.
Quote from: Mark Dalrymple on December 02, 2024, 07:23:17 PMLooking very nice, Tom.
Some very fiddly work executed extremely well.
Mark, Cheers,
Thank you for the kind compliment on the fiddly work. I appreciate the comment.
Quote from: deemery on December 02, 2024, 07:30:04 PMHow frequently do you change your knife blade?  Are you using X-Acto #11, or maybe scalpels?  That's a lot of very finicky work.
Actually, I used only one blade for all the cutting. It's not like cutting the same pattern out of basswood. I probably would have used six or more blades for the wood.
I used the Xacto #11 blade for the file folder cutting.
Quote from: EricQuebec on December 02, 2024, 08:10:26 PMVery nicely done.
Usually when I do this kind of work, I work only with stripwood, on a 1/32 basswood base,
I like doing that :)
Eric QUebec
Eric,
Thank you for the comment, much appreciated. This is the first time I've done something like this but I can see why you like using basswood.
I'll try basswood the next time I scratch build a store front.
Quote from: Jim Donovan on December 03, 2024, 01:34:43 PMLooking great as always Tom. Like I said, if I could model like you I wouldn't need a laser that is for sure. Really impressive.
Jim,
Thank you for the generous compliment. I wish I know how to use a laser but then I'd never get the layout finished.  8)
Again, thank you for the thumbs up on the build.
Quote from: GPdemayo on December 03, 2024, 03:31:52 PMLooking real good Tom..... 8)
Butty Greg,
Thank you my friend for stopping by and the compliment.
Okay, this morning I glued the two  pieces together. I tried to make sure they fit but in the drying process, the top piece shifted slightly to the left.
I haven't decided if I'll cut two new pieces. I still have the window glass and stained glass to install and then I'll make a decision. Weathering may cover some of the shift.
For the yellow I used Floquil Wisc. Central Gold and Floquil Brunswick Green for the darker color.
Bruce Oberleitner
Quote from: ACL1504 on December 03, 2024, 04:50:38 PM
Matt
Matt,
Dang Tom, if you got all that done with only two Diet Pepsi's, remind me to send you some more Diet Pepsi right way!  Awesome job!  The layering looks really cool.  Did you need to seal your parts before you did all that cutting?
Quote from: Bruce Oberleitner on December 03, 2024, 10:13:27 PM
Matt
Matt,
Cousin Brucie,
Yes, only two of the 16.9 Fl. Oz bottles. I've been cutting back and drinking more water.
Thank you for the compliment. I didn't seal the file folder prior to cutting but I will seal them now that the paint has dried.
Now that I have the two layers glued together and painted I decided to seal them. As I mentioned, the storefront is made from a file folder. Since it is a paper product, I want to seal the paper as it we get quite a bit of humidity here in Central Florida.
Two years ago I found a new product at the local hobby shop. it is called Mr. Hobby and it comes in flat, matt and gloss.
It is a bit pricey and I've seen it on Amazon for close to $18 to $20 dollars a can. I got mine locally for about $12.00 a can.
I really like this product as it sprays very smoothly and seeks its own level as it dries. It dries to the touch in 30 minutes.
I turned the storefront over to install the lower windows. I used a product call Dura-lar. It an Acetate alternative.
I used 3M double sided transfer tape to attach the Dura-lar windows. I purchased the Dura-lar from Sam Falx Art Supply.
I cut a strip of tape and applied it to the back of the front wall section.
That Dura-Lar is new to me.  I'll be interested to see the results.
I then turned it over and cut out the tape as shown in the second photo below. I used the inside of the window panels as a guide to make the cuts.
Quote from: deemery on December 04, 2024, 05:30:32 PMThat Dura-Lar is new to me.  I'll be interested to see the results.
I've been using it for several years. Jeff Grove (Carolina Craftsman Kits) told me about it.
It is great, easy to use and cut. Also, the sheets are 9"X12". Perfect for large area windows.
