Pam's Flour Build
Started by Jim Donovan, November 21, 2024, 08:43:21 AM
Jim,
Just, "WOW!".  If I wasn't already amazed by your use of the laser to cut the brick paper I'd be looking for more adjectives to describe the insanity of cutting curved cover glass windows.  I struggle to cut glass for my storefront windows using a straight edge, and often end up by hiding the less than straight cuts I get after multiple efforts. I cannot imagine trying to cut glass for even a couple curved windows, much less a hundred.
Looking really nice, Jim.
Do you have a plan to try to lesson the repeated patten of the bricks?  I know Troels Kirk did some amazing stuff with paints to his walls.  Also George Sellios with those 'Trains of Texas' walls.
Jim,
Fantastic build my friend. This is a great add for a laser cutter. However, I won't live long enough to learn how to use it. I'm sure the learning cure is another story.
Jim Donovan
Quote from: deemery on December 01, 2024, 07:41:44 PMVery impressive!  I've never tried real glass...
Thanks Dave
I've had several comments on cutting glass, especially curved so I am adding a little more information on the post.
Holland & Odessa Railroad
Jim Donovan
Quote from: Zephyrus52246 on December 01, 2024, 07:54:04 PMI've done a few cover glass windows.  I think it would be near impossible to cut the arch consistently.
Hi Jeff;
It is not the easiest thing in the world for sure but it can be done. It is one of those things that the slower you go the faster you will get done. I', posting a little more information on how I am doing this.
Jim Donovan
Quote from: jerryrbeach on December 02, 2024, 09:27:54 AMJim,
Thanks Jerry;
Like I told Jeff, not the easiest thing I have ever tried for sure but doable. I am going to post a little more on it so might give you some ideas.
Jim Donovan
Quote from: Mark Dalrymple on December 02, 2024, 02:14:31 PMLooking really nice, Jim.
Hi Mark;
Yes I will be using dry brushing, and pigments once I have have placed all the detail stuff on the walls and before the glass goes in place. Matt clear varnish will tone everything I put on the walls down. If I do it right (no promises) the repeat should be gone. We will see.
Jim Donovan
Quote from: ACL1504 on December 02, 2024, 05:46:53 PMJim,
Frankly Tom if I modeled as good as you do I don't think I would worry about lasers or 3D printers either. Thanks for tagging along.
Jim Donovan
I've received some comments on the use of real glass and the difficulty of using it so I would like to explain how I do it a little more in-depth. First, like most things, the more you do it the better your results. I like the look of glass so I am willing to put up with the failure rate and frustration of cutting a shape only to have it break on the last cut. Second I have found only one tool that works consistently in cutting slide glass, the General Tool Scribe #86. I'm not sure if it was Bob Parrish or Bob Hamm who told me about this tool first but nothing else I have tried has worked, period.
There is a much better glass available for windows, offered by Clover House, it is an amazing .05mm thick were the slide glass is .13-.17mm thick. I can cut this material with a very high rate of success and I have seen Bob Hamm cut complete circles out of it. Unfortunately they are temporarily closed due to illness. Hopefully they will reopen soon. So for now I am stuck with slide glass but the good part is it is much less in cost since I only get it right 35-50% of the time.
To cut these windows I two step the process. First I make a single score across the slide in the width I want. I don't worry about the height at this point, just a nice straight cut. I use a little tape jig I make on the work mat for this process and a clear plastic ruler to see that the slide is in correct position to score the glass line. After scoring I place the glass on a 2 x 4 metal block I normally use for weight with the score line on the edge of the block. I gently press down and if I scored it right it simply snaps off.  After a little practice this usually goes fine. Then I place the die I had the laser cutter cut out of 2 mil styrene in the dimensions of the window (actually .1 mm smaller in all dimensions to account for the scribe adding width. When stacked correctly I gently score the curve of the die in one direction, towards me,  until the corner snaps off. If done right I have a curved window. Sometimes the curve might not be perfect but if only a little jagged the window frame will cover it and I still use it. Since the window frame is fairly soft resin I slide the glass in place with about 1-1.5 mm sticking out the bottom. Then I gently tap the bottom against the work mat till the glass is completely seated, being glass it works its way into the resin somewhat. If any glass is still showing on the bottom I use the scribe and cut it off. Finally a dab of canopy glue across the bottom of the window which will dry and hold everything in place. So here is a better picture of the  make do jig (the white die is in the correct place when used) and the final result after cutting.  Most of my failures are on the curved part so I cut up 10-20 'straight blanks') first then work on the curve.
Hope that is a better explanation.
Tedious work Jim, but the results are amazing..... 8)
Jim Donovan
One thing I forgot until yesterday. In order to get the cuts as constantly smooth as possible it is important to cut on a hard service, not the mat as I showed. It has been a while since I used glass in a building and had forgotten this most important fact. I have a sheet of tempered glass I use for cutting brittle items, once I switched over to it my success rate jumped to 75%. Not sure why I forgot except old age. The surface you use to cut is all important.
Jim,
Cutting the glass on a hard surface does make sense. Great job  anyway.
Glass cutting 101 etc.!  Thanks for how you do this.
And the build is coming along nicely.
Jim Donovan
I am planning to do as much work on the walls as possible prior to putting them together. For the front I had the laser cut from 2mm styrene the letters for the company name. Painted the same color as the windows here is the result:
Jim Donovan
In addition to finishing the outer walls I am attaching shadow boxes to the inner providing a glimpse of the interior through the windows. I've seen several modelers on the Forum use this technique, the latest being Jeff on his own  winter challenge. As I am lighting the structure I am putting the lighting into the various shadow boxes as needed.
The above photo shows the shadow box for the right side wall. It is designed to show three floors with stock photos of interiors of actual mills. The top floor is where the grain first arrives and begins the process of drying and milling, it then moves down a floor for processing and down another floor for additional processing. Finally on the ground floor it will be packaged into bags or barrels as needed. I am using the same photos and all four sides for simplicity and with the windows in place the interior will be hard to see.
I designed the box shapes using tinkercad and was orgionally going to 3D print them however I decided that was overkill and simply cut 3mm plywood using the laser and glued the parts together as needed. I did design and 3D print slide/ bracing so the shadow boxes can be slid into place, be held firmly to the inner wall and will be removable if needed.  Here you can see the design of the gray colored braces:
In past builds I have had issues with light leakage around the windows and doors. To help solve that problem I designed a simple cardstock backing with the window area cut out. I used the Cameo 3 vinyl/ paper cutter I have to run off 50 of these, glued them to the backs of the window area and then painted them flat black. You can see the window backing cardstock before they were painted in the photo. Hopefully that will take care of the light issue.
