Clearwater Valley Railway Co.
Thanks for the comments Jerry, Rich, Curt, Rick, Larry and Kyle, they are very much appreciated.  The miter saw makes doing repetitive angle cuts consistent. Not only does it speed up production, it makes for very accurate cuts.
Only had to work a half day today and have the rest of the weekend off.  ;D  I decided it was time to tackle the "NBW" issue.  :o
This update is called ........
If I Ever See Another NBW Casting I'm Going to . . . . . . .
Well it was time to drill a gazillion holes for the gazillion NBW castings.
In order to drill the holes required for the NBW castings I used my new mini drill press.  I went through a few drill bits before I realized that the drill RPM was to low, so I ran it at full speed and the broken drill bit problem went away.   ;D
The drill press came with a variable speed controller.
The holes drilled for the NBW castings.
In order to find and prevent the casting migrating I cut then off the sprue and placed them in the ceramic dish. (they look like ants in a dish.  :o )
The NBW casting installed on the first bent.
The four bents completed.
Thanks for looking in.
Outstanding job with the NBW's Ron. I think the hardest part of the task is picking them up with the tweezers. :o
Howdy Ron, the bents with NBSs look perfect. Excellent work as usual.  Have fun, mike
Ron very nice little drill press and the bents look great with all the NBW's installed. Keep up the awesome work.
Ron, that's a neat looking drill press.
Nice job on the NBW's.
Are you using a foot pedal to turn the drill on and off?  Having recently done some trestles, I know how annoying that gets.  The NBW castings in the white dish is good idea.
Great job Ron.  I didn't see any curse words so I assume it went pretty well!!  :)
Where did you get tht drill press??  Or did you make it!!
Just wow!  8) My Unimat lathe has an included column for drilling and milling. A true lifesaver in accuracy. Also interested where you found that drill press?
kyle creel
That's amazing Ron; those are some beautiful bents, ;) nice drill press.
KYLE CREEL
G&D Ry Co.
Thanks for the comments Curt, Mike, Larry, Rick, Dave, Jerry, Philip and Kyle.
Dave, the drill did not come with a foot petal.
Jerry, Philip, the mini drill press is a very recent purchase that I got when I was in Florida.  I purchased it here;
https://innocraftsman.com/products/mini-drilling-machine?variant=42189678411846
So far, I've been very happy with it as it is very quiet and very little to no wobble.  I have been able to drill into the edge of .040 styrene using a micro vice.
#175
Another Productive Day by the Bridge Crew
Now that the bents are completed it's time to start assembly.
First up was to cut the caps and pin them to the template.
Using the template as a guide I positioned and glued the first two bents to the caps.  I let this dry for about an hour before moving to the next step.
The four bents glued to the caps.  Once this had set up it was time to add the remaining cross braces.
All the cross braces installed.
Last step is to install the remaining NBW casting and then this puppy will be done.  ;D
kyle creel
WOW :o  :o ...This 'mutha' is gonna be 'the REAL DEAL' ;)  ;)  ;) ......nice start Ron; love it....... 8)
KYLE CREEL
G&D Ry Co.
Really well done Ron.  Great job!!
Outstanding planning and modeling Ron. I might of missed it from earlier but what color stain was used?
Ron great job of engineering; very neat and precise.
