The Grizzly & Dilapidated Ry.
Started by kyle creel, February 02, 2025, 10:19:09 PM
Howdy Kyle, the trim boards look great.  I hope you aren't as slow at plastering as me.  Have fun, mike
Kyle very nice!! That is looking like a real "professional" layout and the lighting only adds
to the charm.
                            2025 Winter Callenge
Kyle, you're making lots of very good progress.
Nice Job!
Michael Hohn
I like all the progress you've been making.  The mine trestle has a good ad hoc look to its construction.
kyle creel
Thanx Mike, thanx Larry C., thanx Rick, and thanx Michael;
  Now that Easter has "come'n gone"- (I hope ya'll all had a wonderful holiday) I suppose I should 'get back to work' and start on the plastering.  It's SO MESSY, >:(  that it "gives one pause" to begin such an undertaking.  Although this time there's not THAT much area I actually need to do. ::)   I'll 'fill in' between the ramp and the mountain, and also along the side that 'fronts' or parallels the main line.  I'll also need to probably 'fiddle' around in between the various 'hunks' of leftover rockwork I've saved from previous adventures in this sort of undertaking.  I figure it's gonna take about 2 to 2-1/2 days to get it all done...dried, painted & weathered.
  At least after that I can proceed with one of my favorite tasks... installing track ;D  ;D  ;D .  I have everything for my main buss and feeders.  I'm going to use the 'little clamps' instead of soldering every single connection along the buss.  The only solder joints will be on the track.  I've seen so many people in videos use them and all I've read about them is good.  I guess it's like anything else, if I use them properly with the right size wire and connectors I'll be fine.  I'm going to pre-drill holes along the track's route-main and sidings; then I'll insert a short 3" piece of straw about 1/4" in diameter.  I'll poke both feeders up through the straw, and decide then whether to 'pull the straw up and out of the hole, or leave it as a sort of spacer; solder the wires accordingly-red & black; and since there's no loop or turnback in direction-it'll be simple 'RED-outside rail- Black-inside rail'.  The only other thing in regards to track & wiring is adding the auto reverser to the sector plate in Dilapidated; which will be just like I did on the TT in Grizzly. ;)
   Well, that's about all for now.. I'll post some shots once the plaster "has started to be slung" :o  :(  :D  ;D  ;) ....Thanx again for stoppin' by and ya'll keep those cards 'n letters coming.......have fun; see ya  ;)
KYLE CREEL
G&D Ry.
Kyle,
Great use of the repurposed wood, the layout is starting to look real professional now.
The imagineering is panning out (pun intended) 8)
Rail and Tie
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
kyle creel
Thanx Ron, thanx Phillip, and thanx Darryl;
   I,ve done nothing on the RR lately.... :(  :(  :(  I've been toying with the idea of a 4'x 6' HOn3 layout. :o  :o  So I drew up a couple of ideas and posted them on the HO/HOn3/HOn30 Line.  Then I tore (ruptured) my left bicep last Friday (May 2nd) moving furniture.  I completely tore it loose from the bone at the bottom.  It 'hurt like hell';  >:(  >:(  >:(  and I posted all the details on the HO/HOn3/Hon30 Line; so the short versions is...no surgery at my age and with my heart condition.  It'll quit hurting in about 2-3 weeks, take extra strength Acetaminophen for the 'discomfort' and wear a 'support sleve' if you need it.  WHAY????? :o  :o  :o  :o  :o
   I'll get back to work on the RR as soon as I can.... ???  ???  ???  ???  :-\  :-\  :-\  :-\
KYLE CREEL
G&D Ry.
You need to come up with a much better story than that.  When I had rotator cuff surgery, I told people "I got hurt trying out for the Pittsburgh Steelers".  And since my surgery was around Christmastime, I wrapped my sling with a battery-operated string of LED lights...
Hope you heal quickly!!
Best wishes and fast healing, Kyle.
I've seen people use the insulation-displacement connectors on layouts and modules.  But there was one layout that used them in a damp basement. I was asked to get it electrically and operationally ready for an event, and I found a lot of issues caused by those connectors.  Might have been a cheap brand, might have been the wrong gauge wire, might have been the damp.
kyle creel
"OUCH"- OK- Here's my 'war stories' 8)  8)  8)  8)  8)  8)
6-ACL/MCL/PCL tears with meniscus tears in each knee; -football-no surgery only drainings each time
both rotator cuffs are still torn;-football-no surgery
2 blown discs in my lumbar; -lifting stuff improperly-no surgery
and now a torn bicep- moving furniture;-no surgery
30% heart function after heart attack.......no surgery.......
But I did have my tonsils taken out ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
Thanx for the well wishes....... ;)
Well, Kyle, I'd say "Stay away from the Furniture!"   :P
Kyle, sorry to read about your injury.
Get well soon.
Sorry about the set back. At least HO will be lighter. ;)
My shoulder hurts all the sudden.
Get well!
