The Atlas Turntable "slightly modified"
Started by Dave Buchholz, February 11, 2025, 11:25:43 PM
Dave Buchholz
Believe it or not, this is a good "ol  HO standard gauge Atlas Turntable. It has been buried underneath the table with this superstructure. I liked it as the basis of construction due to the consistent alignment of the mechanism  to the tracks. Burying it, also hides the motor and gears.
it is now HOn3. But since  it no  longer relies on the original structure, the  process of building could be adapted to most any scale or gauge.. I could see this bring easily used for S or an O gauge line by simply being careful of intended locomotive length.
robert goslin
Nice one Dave.  So is yours just turned with the manual handle somehow, or motorised ?
Regards  Rob
Melbourne,  Australia
Dave Buchholz
#3
It is motorized with the original motor in place.. It has a false top to it of course, to bury the original mechanism completely beneath the layout.
The "drive" is simple. It's a square ⬛ 1/8 female  stereo plug soldered to the original lower rails. It could have been mono instead of stereo. I simply used what I had handy from other projects
By using the third contact in a stereo plug. It  could allow a constantly lit lamp, possible powering the ring rail at some point. But not at this writing time.
 A square box  tube of styrene was pieced together and fitted tightly around the plug. It extends upward into the bottom of the wooden "A" frame  bridge. I made it a little longer than expected to allow for finally trimming to size.
By locking the box around the plug into the upper wooden "A" frame bridge,  it ,allows movement of  the lower hidden table and upper frame in unison. A simple matching  male 1/8  plug is soldered to the "A" rame rails to provide power. It rests inside the square tube
It's very reliable and can be easily worked on, as the A frame simply unplugs from the base
By no means am I the first to use the Atlas table in this manor. I'm just the first to make a fishing hole out of it for the local residents. Every storm from the north, crashes over the rocks. With any luck, some lake trout or salmon get thrown over the rocks as well.
Ok that story sounds fishy.  But it's my story and I'm sticking to it.
Fifth Dave to the right.
A turntable turned into a great scene, good work Dave..... 8)
Wow. Great work...I've obviously seen them re-purposed like Malcolm Furlow did by just gluing a bridge detail on top but you've gone to a much higher level - the pit looks great too- very unique.
IWannaRetire
Quote from: Dave Buchholz on February 11, 2025, 11:25:43 PMBelieve it or not, this is a good "ol  HO standard gauge Atlas Turntable.... It has been buried underneath the table with this superstructure.
I like this idea a lot, and your execution of it as well. In searching now for the Atlas HO turntable, all I see is a covered deck version.  Was that your starting point?  Am I understanding correctly that you built everything visible in the photo, including the pit rail?
Very nice!
Atlas describes it as a 9" diameter, is 9" the length of rail on your bridge?
Mark from Illinois
Dave Buchholz
#10
Quote from: IWannaRetire on February 12, 2025, 09:20:59 AM
Yes. The typical flat Atlas turntable  was indeed the staring point. Since we are building a pit bed above the Atlas unit, the depth of the pit and length of the "bridge" can pretty much be anything you imagine, easily up to 12 inches.  You could make one  side dug  into a hill and the other side on  one stilts.
The key is really going to be how much slop or slackness of the fitting is allowed  used to connect above and below together.. That's why the square plug and tube must be tightly fitted and shimmed so it lines up with rails originally and when 180* around. It used an exact online and thin plastic shims to finish the fit.
I'm at work during the day. I will try to post up a few pics  of the preliminary stages of the build later tonight.
Dave
robert goslin
Thanks for the extra info Dave.  I think I understand what you're saying, but pictures are always better, and would be appreciated.  So with it being motorised, does the indexing still work ?
I would really like a turntable and don't really want to spend the many hundreds of dollars to get one of those flash ones.
Regards  Rob
Mr. Critter
Very fine.  And I love it that you've posed a weatherbeaten old Shay on it.  Geared locomotive aficionado, here.
Dave Buchholz
#13
As Promised, here's a few photos of how the North Coast Turntable was modified from a Basic Atlas Turntable. First off, I do not claim to originate this idea. I simply adapted the idea  for my use, that others in the hobby before me, introduced.
First is an example of simple overlay and framing, without any pit, made by another modeler years ago. This would be unburied
and installed on his layout.
Here's another example of other inspirations I've collected for future ideas. In particular, I've always thought this was was absolutely awesome! Like how the pit rail is over the side of a hill. It inspired me to keep one side of the pit more open.
Dave Buchholz
#14
 This is how I built the turn table for the North Coast Railroad.
Building up the base with  a 1/8" jack soldered to the rails.  It would not have  mattered to use a mono vs Stereo Jack. The minor caveat if using all three rings of a stereo plug. You could light the structure used a powered ring and the return ground. It might have  have a polarity issue though Haven't given it much thought.
It was also "JB Welded" (Glued) to keep it secure. You can see the spacers that the pit base will be fixed to Turntable 1.jpg
You see how this will be buried under the benchwork. I cut away the plywood to give the drive motor clearance
 The motor is simply covered by pink foam
