15JUN25. Fathers’ Day
Started by KentuckySouthern, June 15, 2025, 10:00:43 AM
KentuckySouthern
Greetings to all those father's among us today. 8)  Sunny and seasonal weather today here in Michigan. I hope everyone has a wonderful day
The  ;) old van has been dusted off and ready. The kids are taking us all out to breakfast at the local spoon. Tain't Mothers Day so don't expect the Ritz.  ::)
Happy 250 to the Army. I loved your parade. Shame on the political bs.
Headed to a daughter and son in law's home this afternoon.
Be well all. Don't forget your card. You may get stuck paying. ;)
KS
Orionvp17
Mornin,' All!
63, headed to 74 under the ritual grey blanket here in the northern mitten today.  I suspect Manitoba smoke, but who knows?
Happy Father's Day to those who are, and best wishes to those who aren't.  Enjoy every day... we don't get all that many of them!
Make it a great day, All, and stay safe!
Pete
in Michigan
I put another coat of paint, this one on the back of the parts I cut yesterday, to protect them from sun damage.  Later today I'll install the framing, and tomorrow a neighbor will come over to hold the blinds while I attach them to the frame.  Then a bit of caulk to patch some small mistakes and make everything look smooth and finished...  At least that's the plan...
In the meantime, I'll probably head down and think a bit more about the line shafts for the machine shop.  I need to select the pulleys and do a layout of them.  I don't think I'll drill through the cone pulleys, just a bit of drilling at each end, so the line shaft will end up being several pieces connected at the cone pulleys.  I also need to think about shifters, although watching some more machine shop videos, one guy just uses a broomstick to shift the belts.  I didn't realize they'd move that easily.  There's another Iron_Jonsey video, this one of a shaper doing its thing.  Watching machine tools work is so hypnotic!
Morning all,
Late afternoon here. Dang it, two days before we fly home and I'm congested. Either allergies or a mild cold. I'll plow on tomorrow because it's Black Forest day.
Have a great one!
Bob, I learned the hard way to always travel with a couple allergy pills in my carry-on.  Flying home with a head cold is miserable!
Sunny right now.  I'll check the pieces I painted earlier this AM, if they're dry enough, I'll take them upstairs and install them.  Otherwise, down to the train room...   ;D
Orionvp17
If that's a head cold, I'll highly recommend that you postpone the return if at all possible.  As Dave mentioned, allergies react to pills, but head colds don't, and you can do serious damage to your hearing if there's an incident on the plane due to emergencies or rapid descents.  Stay safe!
Pete
in Michigan
Well....  I mis-measured one inside opening on the skylight project, which I didn't find out until after I nailed in that piece and tried to test-fit the blind assembly.  What I -should have done- was pried up the nailed-in piece. cut it down.  But since I couldn't see how much I needed to remove from the top, I tried sanding, then chiseling and finally cut out the bit of top molding around the skylight.  That took a lot more time than if I had redone the bottom piece.  This is the difference between amateurs and pros.  The pros know how to adjust from a mistake.
The other blind fit OK.
KentuckySouthern
Quote from: deemery on June 15, 2025, 03:18:33 PMWell....  The pros know how to adjust from a mistake
Or they've made it on someone else's dime.
 :o
Quote from: KentuckySouthern on June 15, 2025, 04:26:37 PM
 :o
But they still have to -fix- the mistake, regardless of who pays for it.
