Rick, Tom, Rich, Curt, Philip, Larry & Jeff thanks for the compliments.
Larry I'll have to try that thanks for the tip.
OK Jerry, you have a dock, where is the water  ;D
Great job on the dock.  I'm guessing from the size of the dock, you have some kind of structure for it?
I'm not sure how I missed this thread, but it sure looks intriguing. 8) I'm loving what I'm seeing so far.
Howdy Jerry, the dock build continues to look amazing.  Nice work on the decking.  Have fun, mike
Ron were in a drought right now!!!  :)
Thanks for the nice compliment.
Thanks Bob it's appreciated.
Thanks for looking in Mike appreciate it.
kyle creel
Super job Jerry ;) ....Where do I send the order form, and what's the turn time??  ;D  ;D
KYLE CREEL
G&D Ry Co.
Thanks Kyle orders won't be taken until!!!!  :)
Glad you like it so far.
The inside framing is done. Framing is 4x8 with 1/32" scribed siding.  Stained with Minwax Golden Oak.
My lightning screws up the stain.
More to follow later.
The outside is made of 2x12 planking coated with 1 to 3 coats of SilverWood Stain.
The doors are stained SilverWood then white over that and peeled with mineral spirits and scotch tape the Chuck Doan way.
Jerry Fantastic job on the framing and inside/outside siding. Luv the doors; I may have to borrow that technique sometime. You are the "Master of framing."
Quote from: Larry C on July 05, 2025, 03:05:32 PMJerry Fantastic job on the framing and inside/outside siding. Luv the doors; I may have to borrow that technique sometime. You are the "Master of framing."
Thanks Larry.  it an easy way to do peeling and it works every time!
You know Jerry, that I now have silverwood stain. I might just have to use some to see if I can achieve what you have shown us. Those wood planks are superb! I know lighting is also a small problem, but the dock pictures (shown earlier) look a little darker than the outside wall pictures, or it may be my eyesight. I was thinking that silverwood stain would be more darker though.
And Larry is correct when saying that you are the master of framing. How did you make the door rollers/pulleys?
Jerry everything looks top notch. Love the framing and the colors.
Jerry, inside and outside colors look excellent.
And so does the peeling paint.
Jerry,
I see the master framer is at it again.
Great job on the walls and doors, I'm thinking I need to gewt some of that silverwood stain.
