Hank's Machine Shop
Time for an update:
Wanted to make an elevated support for the water tank so gravity would allow the water to flow into the boiler. It's 7 ft high and 8.5 ft long, just enough to accept the tank. Used 8x8's for the frame so I ended up with a "beefy" look. The diagonal supports are 2x10's then added 6x6's on the very top to help hold the tank in place. All the wood was grained, colored with raw umber chalks & clear alcohol; when dry I added a liberal coat of A&I. Also added some NBW's for a little bit more detail.
Here's the end view as it will sit facing the outside right of the diorama. Next will, of course, be to paint the tank before weathering it a bit. Thanks for stopping by and for all your great comments and/or suggestions; they're appreciated.
Looks great Larry.  Nice coloring.
Curt and Jerry thank you both.
Nice work Larry.
NBW's are a nice touch.
labdad
Water weighs a lot!
You don't good.
MJinTN
Rick thank you and a little more detail never hurts.
MJ thanks. That's what I was thinking when I was considering what size of lumber to use.
Howdy Larry,
The tank stand looks perfect.  The little details make the stand believable.
Larry, that is one hefty stand, it should hold a lot of water.
Ron thanks. The tank I'm using is decent size so ya needed something a little more hefty.
Philip working on it. Lol.
