CCK Doc Koontz Build
craftsmankits
A toothpick also works well when coloring individual bricks. I usually add a little water to the paint to ensure it flows properly.  Mark
Tom nice job on the rafter tails; that's the one thing I hate doing. Nice toothpick tip; say that 3 times.
Quote from: Rick on January 20, 2026, 05:04:49 PMTom, I agree about the sloped roof.
Nice tip about the toothpick.
Rick,
Thanks for the comment and stopping by.
Quote from: Philip on January 20, 2026, 07:15:44 PM8)
Yep!
Philip,
Yepper in deed!
Quote from: craftsmankits on January 20, 2026, 07:50:38 PMA toothpick also works well when coloring individual bricks. I usually add a little water to the paint to ensure it flows properly.  Mark
Mark,
I agree, the toothpick trick works for many small projects. Since the Floquil Zinc Chromate Primer is oil based, I used thinner. Same as using water for Polly Scale.
Quote from: Larry C on January 20, 2026, 08:43:21 PMTom nice job on the rafter tails; that's the one thing I hate doing. Nice toothpick tip; say that 3 times.
Larry,
Thank you, much appreciate the comment and your time to stop by. I can barely say it once, let alone thrice.  ;D
I didn't get much done on this build today. I did get the canopy glued to the front.
I need to add additional weathering, the sign and canopy wire supports.
I also have the strip wood ready to stain and paint for the rear outside stairs.
EricQuebec
you did a very good job on this one :)
Eric Québec
Outstanding Tom. The canopy looks perfect.
Tom you really did an outstanding job on this one.
Good thing patience is you middle name!!  :)
Tom, the canopy really adds a ton of character to the building.
Quote from: EricQuebec on January 21, 2026, 05:03:34 PMyou did a very good job on this one :)
Eric Québec
Eric,
Thank you my Canadian friend, much appreciate you following along.
