Ron nice work on those doors.  Very neatly made.
Looking good, Ron.
I like the door handles.
Thanks for the comments Larry, Rick, Curt, Jerry and Mark, they are really appreciated.
Stay tuned for another update shortly.
More work today on the challenge build.
This is what I call "Poor Man's Tar Paper"
'Poor Man's Roofing" is made using a simple Kleenex, or tissue.
First step is to separate the plys.  Once that is done I mark lines every scale 3 feet.
The strips are cut using a very sharp pair of scissors.  I tried cutting the strips with an x-atco knife with a brand new never before used blade but it tends to tear the tissue rather than cut it.
Attaching the tissue to the roof is easy.  I used Tamiya flat black (XF-1) paint to "paint" the tissue to the roof.  Because the tissue is very porous the paint bleeds through the tissue and into the roof.
The tar paper installed on the roof.
"Poor Man's Tar Paper" - Part 2
I used a black Sharpie to add "tar" along the seems.
Last step is to weather the roof using chalks.
At this point, I'm calling the roof completed.
And Then There Were Lights....
I decided to add lights to the building seeing as the one of the front doors will be completely open.
I used ACC to glue the SMD LED to the peak of the roof and also glued the wires along the rafter to the back wall.
Testing the LED. (OK, I did test the LED before installing it  ;D )
The wires were then glued along a stud down to the floor.
Final Pictures ......
Front view of the building.
The left side of the building.
The backside of the building.
The building mounted on the loading dock.
A night time shot.
Next up is building #2 - The Rigging Shed made by Sierra West Scale Models.
Ron great job on the building. Was this one a SW kit or a scratch build; just curious because Brett usually supplies tar paper with his kits.
Ron, that's an excellent technique for tar paper and you did it perfectly.
Adding the light was a nice touch too.
I agree with Rick on the tarpaper roof.  Great coloring on the wood as well.
Howdy Ron,
Are you sure that roof won't leak? Excellent work as always. The maintenance building looks fantastic.
Quote from: Larry C on February 08, 2026, 07:53:42 AMRon great job on the building. Was this one a SW kit or a scratch build; just curious because Brett usually supplies tar paper with his kits.
Thanks Larry,  It is a SW kit and Brett did supply tar paper, but it was too thick for the look I was looking for.
Quote from: Rick on February 08, 2026, 08:05:17 AMRon, that's an excellent technique for tar paper and you did it perfectly.
Thanks Rick.  I've used that technique before.  The light gives me an option if I want to light the building in the future on the buildings are installed on the layout.
