Ron the stringers look really good, nice and straight. That's going to be quite the landing dock when finished. Keep at it and enjoy.
Ron that is some outstanding work.
Those stringers are in perfect alignment!!
Quote from: Rick on January 22, 2026, 06:14:44 AMRon, excellent job of building and assembling the stringers.
Getting them nice and straight like you did isn't easy.
Thanks Rick,
I would have taken a lot harder to align everything without the jig.
Quote from: Larry C on January 22, 2026, 09:46:01 AMRon the stringers look really good, nice and straight. That's going to be quite the landing dock when finished. Keep at it and enjoy.
Thanks Larry,
It needs to be sturdy is it will support 3 buildings and a ton of junk when completed.
Quote from: Jerry on January 22, 2026, 10:43:48 AMRon that is some outstanding work.
Thanks Jerry,
Without the jig, getting everything in perfect alignment would have been a near impossible task.
Nice progress, Ron.
Its certainly a beefy deck!
Quote from: Mark Dalrymple on January 22, 2026, 03:19:22 PMNice progress, Ron.
Thanks Mark,
It does looks beefy  The stringers and posts are scale 8" x 8"
Howdy Ron, nice work on the stringers.  They look professionally built, so straight!  Have fun, mike
Good so far, Ron.
Nice coloring on the stringers and wood.
Ron,
I'll agree with all the other comments on your stringers. Great job and the coloring looks natural as well.
Looks like a neat project with some interesting kits Ron. Have fun and I'll be looking in..... :)
While not really a construction update I thought I would show how I stain the wood for the deck.
Step 1 - Distressing the wood.
This is easily done by scraping a razor saw along the length of the strip.  I used a couple of different razor saws with different teeth spacing to variety the grain pattern.  I distressed both sides of the wood so that I didn't have to worry about which side to use when gluing the planks to the loading dock.  The byproduct of using this method is that it leaves "fuzzies".
Step 2 - Eliminating the "fuzzies"
Getting rid if the "fuzzies" is done by using steel wool.  This is done by wrapping the steel wool around the wood strip and pulling in over the strip multiple times.   Word of caution: wear gloves when doing this as the steel leaves metal slivers during the process.
Step 3 - Cutting the wood to size.
The distressed wood was cut into a scale 12ft (3") length.  The reason for this is that it will vary the board length when installing and that the ends will be stained during the staining process.  For the record, the planks are a combination of scale 2 x 8's, 2 x 10's and 2 x 12's.
Step 4 - Preparing to Stain
The lumber was then divided into 3 semi-equal piles for staining.
Step 5 - The Staining process
In order to vary the boards, three different stains was used, Hunterline's Driftwood stain (left), Indian Ink and Alcohol (center) and a home made concoction made from various craft paints and water.  This was made years ago and I don't remember the recipe.
