2025-2026 Winter Challenge - AMB Interlocking Tower
Started by ACL1504, January 23, 2026, 04:38:06 PM
Like Dr. Jeff, I've chosen the American Modelers Builders Interlocking Tower kit as my '25 challenge build.  AMB made several different kits. I understand the owner passed away and to date no body is picking up the line.
Many of you know I just can't build a kit straight from the box. I tend to think outside the box and add my own spin to the kit. This build will be no different. I certainly won't be doing 50 pages on this build as I did for last years challenge.
I do have a few ideas I'll add to the build but it will be pretty much a kit build.
Here are the obligatory photos of the kit.
The walls a slot and tab. Not my favorite type of kit.
Over the past few years, I looked at this kit trying to decide to build it.
In the next photo note the missing roof brace.-It fell out at one point while checking the kit. I have no idea where it may be.
I'll need to make another one.
When built, it will replace the FOS Tower shown below.
The FOS Tower will be relocated at the north end of the diesel lubritorium.
Tom glad you decided to jump in so I'll be following along.
Quote from: Larry C on January 23, 2026, 04:47:42 PMTom glad you decided to jump in so I'll be following along.
Larry,
Thank for following along on this journey.
I used the other roof piece and trace it on the same carrier sheet.
Fast forward and I cut it out and made the initial test fit. It does fit and looks like the other one.
My copy is on the left.
I went ahead and glued the parts to the interior roof section.
Done for today.
Tom, you know as usual I'll be here to follow along.
Nice job replicating the lost piece.
You'll find that piece after you're finished building the kit?  ;)
I know you have a good reason, but why are you switching the towers around?
It looks like you and Jeff are of like minds, Tower #702. Looking forward to seeing your build Tom..... :)
Vietnam Seabee
Terry is here in the second row with a large Diet Pepsi
You will find the missing piece right after you finish the build.  ;D  You made an exact copy of the missing piece looking at the build to date, as per your usual style.
I will be in the second row beside Terry following along.
Quote from: Rick on January 23, 2026, 05:18:08 PMTom, you know as usual I'll be here to follow along.
Rick,
Thanks for jumping in and following along and thank you for the nice compliment.
Replacing the one tower is just personal preference. Call it for aesthetic purposes if you will. The current tower is a FOS tower I built some 10 years ago. I like the kit but it just doesn't look like a signal tower to me.
Quote from: friscomike on January 23, 2026, 07:13:54 PMHowdy Tom,
Tower on brother!
Mike,
You betcha! Yepper, I'm still having fun.
