O'Neils Mercantile & Repair
Jerry thank you so much. I think that's what drew me to dioramas because you can view it from all 4 sides as opposed to a layout where you're stuck with 1 viewing angle; plus you can have more variety in what you model.
Been going back and working on little things so I don't forget anything; couldn't possibly be old age sneaking up on me...nah.This guy is my 3rd LP and is busy at work at the bench.
The push broom and gas can are items from my stash box. The hand operated drill and oil barrel on a stand along with the "oops pail" are from Sierra West. I originally wanted to put the drill on a post in the front area but there was no way my mitts were going to fit a post in place so I pivoted and placed it under the eave on this side of the opening. Drill and oil barrel were colored with chalks and clear alcohol with the rest of the items painted and/or weathered. I also added some metal shavings on the drill plate and floor.
I opted not to place a LP in the saw shed but I did adds lots of real sawdust and 3 boards stacked up on the end roller to look like someone had been hard at work. Now I have to do some serious "canoodling" and figure out the remaining scenery, what cameo scenes I want to make, and where to place everything.Once I figure out the cameo scenes to include I'll build each one then play "cameo roulette" to get everything where I want them....should be fun. Thanks for stopping by and for all your great comments and/or suggestions so stay tuned.
Larry your first photo is outstanding. Who made the figure in that photo? You did an excellent job painting it.
Curt thank you so much. All the figures are 3D prints from Rusty Rail. I do spray paint them with a grey primer first then I go ahead and use chalks & clear alcohol to "paint" them. When dried I dry brush them with a darker color from the base color to help bring out the fine details. The only paint used after priming is a flesh tone paint for the skin areas.
Looking great, Larry.
Philip and Mark thank you, much appreciated.
Larry your really doing a bang up job on this one!!  Wonderful work!!
Larry, details look very good.
Nice work.
Jerry and Rick thank you both. This is the really fun part for me....details.
Larry,
All those added details really make the scenes "pop", can't wait to see what you do next.
Ron thanks; the details really help to tell a story.
Been working on scenery a little bit at a time. Finished up around the tracks by adding some grass, clumps of weeds, some bushes, and of course lots of dirt. Added some junk between the rails but kept it to a minimum. All of the junk came from my parts box and weathered heavily.
The Ford tractor is a Sierra West item which was a 1 piece item except for the tires. Sadly I accidentally broke the seat but was able to reconnect it after the tractor was colored. After priming I used a blue/grey chalk & clear alcohol to color part of the tractor. For the frame and wheel centers I used a dark brown chalk with clear alcohol. The tires were spray painted flat black then weathered with light brown chalks when dried. The seat, steering wheel and shifter I used black chalks to color them.
This is the other side of the tractor. Next I'll finish working on the items for the rest of the tractor scene; probably a make shift workbench with tools, a couple of LP's talking over the situation, and whatever else I find to fit the scene. Also I'm going to put down the scenery material in that area before I assemble the scene. Thanks for stopping by and for all your great comments and/or suggestions so stay tuned.
Nice job on the landscaping. I like how the rail ties are almost all covered up.
Howdy Larry,
The diorama looks fantastic.  Every little bit you add makes it even better.  Well done.
