O'Neils Mercantile & Repair
Micheal thank you; appreciate the comments.
Been making some nice progress with all these rainy days. The decking on the side of the Mercantile is made out of 2x10's, grained, weathered then constructed on a piece of 110# paper which has been glued in place. The second story porch from 2x10's for the flooring and 3x12's for the frame treated in my usual manner. The supports are 6x6's and the cross brace is 1x6's. Also the landing, that's sitting on the deck atm, will of course be raised up to meet the first set of stairs and the second set will come off the front of the landing; waiting on that part of the construction for a bit. The rear decking and the Shop floor won't be glued in place for awhile.
The decking across the back is a copy of what's on the side. The next area back is the floor for the Repair Shop. Started with another piece of 110# paper for the base cut to size then added 2x10's for the floor boards again done in my usual manner. I did glue each strip in 3 pieces to look more realistic. The rails were a little tricky to install. After I had some of the flooring glued down I then used super glue on the bottom of the first rail and placed it tight against the flooring. Grabbing my track gauges I placed them on the glued track then ran glue on the bottom of the second one then quickly set it in place and made any adjustments before the glue had a chance to set up. After everything had dried I finished the flooring; this I also glued each strip in 3 pieces staggering the joints.
Since I have already determined the rest of the hand laid track will be set on 2x10 ties I needed to raise the floor up a little bit. I used more 2x10's and framed out the underside of the floor which also stiffened up the floor quite a bit. There will be a 2 inch difference between the back deck and the Shop floor but that I can live with.
I wanted the Shop building to be a little past the Mercantile so it's somewhat visible when you look at the front of the diorama.
Next I'll continue working on the outside walls of the Shop covering the cracks between the 2x10's with 1x4's just to add more interest, which is almost finished. Then it's on to detailing the Shop interior  before the walls can be glued together then to the floor. I'm also toying with the idea of adding a knoll behind the Repair Shop so the diorama doesn't look so flat. Thanks for stopping by and for all your great comments and/or suggestions so stay tuned.
Very nice Larry. Everything looks great.
Looks great Larry.  Your keeping everything in line and greeat job on the coloring.
Curt and Jerry thank you both; much appreciated.
Larry,
It looks wonderful and will be a great addition to the overall area. Love the weathering on the roof.
Howdy Larry,
O'Neils is looking good. I'm looking forward to the steps.
Tom, Mike, and Philip thank you also much; it's coming along. The steps I'm waiting on for now since my big hands like to break stuff.
In between everything I have found some bench time:
The Shop floor has been weathered with grey, some brown, and a smidge of black chalks worked into the wood with a soft brush; also the floor has been glued to the foam since it had to be weighted to make sure it laid flat. The building however has not been glued down yet. I did decide to add some 1x4's to the seams of the 2x10's for added interest.
Here's the back of the Shop and as you can see by the door sizes it's very much has an open air feel to it. Also I have started working on some of the details for the interior. Made a workbench, colored a trash can full of debris and on the left front wall you can see a chain hanging on a nail. I didn't add the 1x4's over the door openings since they really won't be seen when the roof in on.
The other end of the Shop.
Second part:
The workbench is made from a stack of wood blocks, resin castings, and colored with brown chalks with clear alcohol then given a liberal coat of A&I to bring out the grain. The top is 2 pieces of 3x10's given the same treatment. If you look at the top of the end entrance you'll see some items on a shelf.The piece of foam behind the Shop still needs some more work and will hopefully transform into a knoll to break up the flatness of the diorama; along with a few other tricks up my sleeve.
Here's a better shot of the shelf items which were colored with various chalks and clear alcohol.
Next I'll continue with some more details for inside the Shop and I do have a couple of items from SW coming for it as well. Thanks for following along and all your great comments and/or suggestions; they really do help.
It's really starting to come together.
Curt hope you had a nice vacation; nice to see you back. Thanks. The biggest challenge is trying to think ahead and do things in an order that makes sense so I don't make things difficult for myself.
Howdy Larry,
O'Neils is looking good.  The board and batten siding does add interest. Good call.  What are you planning for a roof?
